Installed: Springs, Spacers, Brakes. *pics*
Old Sep 30, 2006 | 08:22 AM
Hella's Avatar
Hella
Default Installed: Springs, Spacers, Brakes. *pics*
Just had Stoptech stage 2, and eibach pro kit installed. I have ichiban spacers as well: 15mm/25mm.
pics:
Old Sep 30, 2006 | 08:36 AM
mario60185's Avatar
mario60185
Chicago Realtor
Wait till those springs settle, it takes a while, then its going to look super hot. Can ou post your wheel specs and offsets, im curious as to how the spacers worked for you. I havaae 18x9 and 10.5 wheels with 30 offsets and i wanna pull the wheels out a lil too. But not sure if i would need new wheel bolts or if just buying spacers will do.
Old Sep 30, 2006 | 08:53 AM
wantsa350's Avatar
wantsa350
nice
Old Sep 30, 2006 | 10:27 AM
Hella's Avatar
Hella
they are 03 track wheels. Not sure of the specs.
Yeah the springs are only 3 days old......they look lower every day.
Old Sep 30, 2006 | 10:46 AM
Brick-Z's Avatar
Brick-Z
Been driving with the stage II for about a month now and love it. Looking at yours, kinda makes me wish I went with the drilled rotors instead of the slotted ones.
Old Sep 30, 2006 | 12:57 PM
DMK's Avatar
DMK
Do you think you could have gone with 20mm spacers in the front? Where did you get the spacers?
Old Sep 30, 2006 | 05:14 PM
Hella's Avatar
Hella
yeah with the stock rubber you could do a 20mm. Im getting bigger tires up front next round so I left some growing room.
There ichiban spacers...........i dont remember which vendor i used.
Old Sep 30, 2006 | 05:41 PM
k3silk's Avatar
k3silk
No lie that $hit looks NICE man nice job of turning you stock wheels into a lil eye candy.
Old Sep 30, 2006 | 05:42 PM
k3silk's Avatar
k3silk
Im waiting to see someone paint there 06 rims im sure it will look good too.
Old Sep 30, 2006 | 06:17 PM
Vamos_Rafael's Avatar
Vamos_Rafael
does the spacers make wheel bolts "shorter" per se?
Old Sep 30, 2006 | 07:06 PM
mario60185's Avatar
mario60185
Chicago Realtor
Not shorter, but you will have less bolt to turn the lugs on, thats what im curious about, what if the bolts no longer long enough in certain situations? And how would you know if you would need longer bolts?
Old Oct 1, 2006 | 08:48 AM
jasonlee4180's Avatar
jasonlee4180
I'm pretty sure these spacers of this length all come with new studs. So the spacer itself goes over your original studs and are tightened down to your stock hub. Then the spacer itself has its own studs to hold your wheel.
Get the idea? Its not how a couple of you are thinking.
Old Oct 1, 2006 | 12:18 PM
Hella's Avatar
Hella
As far as the spacer are concerned.... The 20mm are the type with new studs built into the spacer....i think they call them DRM type. The 15mm is a just a spacer but comes with new longer studs.
Old Oct 1, 2006 | 02:32 PM
DMK's Avatar
DMK
Was it hard to install the studs? I know that Ichiba spacers don't come with them pre-installed. These are hubcentric? If you had 245's in the front, would the 20mm spacer work up there? Thanks again.
Old Oct 1, 2006 | 06:05 PM
Hella's Avatar
Hella
the front ones were more of a process. I had my shop do them. Without air tools it might be hard.
They are hubcentric. No rings.
I think a 20mm with a 245 would be almost too much. I have 225 up front now. 245 in the rear so you can see the difference.
Old Oct 1, 2006 | 07:08 PM
baileyrx's Avatar
baileyrx
nice drop & spacers
Old Oct 10, 2006 | 12:30 AM
ichibausa's Avatar
ichibausa
Nice Rims W/ Spacers!
Old Oct 10, 2006 | 06:00 AM
THE TECH's Avatar
THE TECH
Interesting wheel color choice.
Old Oct 10, 2006 | 07:29 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Nice pics! Did you paint or powder coat you wheels? Looks hot!
EnjukuRacing
Sep 30, 2015 06:55 AM
