Quick Question
Old Oct 3, 2006 | 02:47 PM
NA&CH's Avatar
NA&CH
Default Quick Question
Hey guys and Gals.
I just got my HKS LS+ coilovers installed along with Cusco F&R sways, Cusco Front a-arms and SPC rear camber/toe bolts.
Heres my question: Its all aligned(sp) and dialed in. But it is way to high. Higher than my mother stock ZR. Can the shop and I lower it without ruining the specs? The alignment cost 210.
The car feels so much better. I had eibach springs. Thats it. Turns awesome. I need take it to the track.
Thanks for your help.
Chris
Old Oct 3, 2006 | 03:29 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
depends where you are at now, and your wheel specs/tire sizes
what is your height now from the fender centerline to the ground front and rear?
def should have called me for the Cusco/SPC stuff too...but that's a seperate discussion
Old Oct 4, 2006 | 05:37 AM
NA&CH's Avatar
NA&CH
Yea I know Adam. I bought it all used. Sways cost... well a good deal imo. The front arms..semi good deal.
The wheel and tire specs:
18x9 et22 RGII's front with 265/35/18 Sumitumo htrzII tires
18x10 et25 RGII's rear with 285/35/18 Sumitumo htrzII tires
Front Drivers side: 25 3/4 from centerline to ground
Front Passanger: 26 1/4 " " "
Rear Drivers Side: 27 1/4 from centerline to ground
Rear Passanger: 25 3/4 " " "
Well now that I have those measurments, I knew my car sat werid. Well now that a differnet story. I am going to talk to the installer. and see what he will do about the different heights.
Thanks Adam. and all others to help.
Chris
Old Oct 4, 2006 | 06:50 AM
Z1 Performance
Former Sponsor
definitely fix that rideheight - that is going to throw everything out of whack - of course you are going to have to realign afterwards.
Old Oct 4, 2006 | 07:09 AM
NA&CH's Avatar
NA&CH
ahh $hit. Thanks Adam. So the car is aligned for a wack suspension??!?
Thanks
Chris
lapham3
Oct 7, 2022 03:15 PM
issyz
Jul 2, 2017 03:04 PM
