Stearing wheel off center, easy fix?
Old Oct 6, 2006 | 04:40 AM
Enron Exec's Avatar
Enron Exec
Default Stearing wheel off center, easy fix?
My steering wheel was left off center by like 1 teeth from the last time i got my alignment done. Does anyone know how i can get it back centered? Can i just turn the wheel completely to one side and jerk it firmly until it clicks into the next teeth? Ive seen this done on a 4-Runner.
Thanks!
Old Oct 6, 2006 | 04:49 AM
Kolia's Avatar
Kolia
So you removed the steering wheel ?
or is your alignement simply off ?
You won't be able to jeerk the steering wheel to an other spline...
Old Oct 6, 2006 | 05:16 AM
Minda's Avatar
Minda
I believe there are just two options:
Either remove the wheel, turn it by one tooth and secure again; or
Realign the wheels.
As far as i recall there is a special screw nut which hold the steering wheel in place, hence make sure you have the right tools.
Old Oct 6, 2006 | 05:47 AM
Enron Exec's Avatar
Enron Exec
The alignment is fine. The steering wheel is no 100% centered.
Hmm .. taking the steering wheel off eh? I dont think im gonna go and do that. ;P Time to go find a professional. lol
Old Oct 6, 2006 | 06:16 AM
Kolia's Avatar
Kolia
Dude, if the steering was never removed, then your alignment is OFF. Have the guy that did it redo it for free.
Part of their job is to make sure the steering is centered before they adjust the front toe.
Old Oct 6, 2006 | 10:23 AM
350Zteve's Avatar
350Zteve
You're going to have to do the adjustment through the tie rod ends.
Old Oct 6, 2006 | 11:10 AM
k3silk's Avatar
k3silk
thats my problem i have it bothers me cause its not 100% dead on i my installer try about 3 diffrent times to do it but we could get it line up 100%.
Old Oct 6, 2006 | 11:45 AM
The steering wheel position is adjustable by disconnecting and reconnecting the steering linkage. Anyone who has installed headers is aware of the linkage and coupler. I will post some photos when I get home.
Old Oct 6, 2006 | 01:14 PM
a. Remove black linkage coupler.
b. Align steering wheel. You will notice that the upper portion of the linkage (black) turns.
c. Install coupler.
Old Oct 6, 2006 | 02:11 PM
350Zteve's Avatar
350Zteve
If you do this you run the risk of messing up the steering angle sensor reading. If you do this, your VDC light will stay on, traction and stability control won't work, and only a dealership with the Consult II will be able to reset the sensor.
Old Oct 6, 2006 | 02:39 PM
OH. I don't have VDC.
ablaine
Nov 29, 2016 10:13 AM
kyin
Oct 15, 2015 05:54 AM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
