Cusco A-Arm adjustment
Old Oct 20, 2006 | 12:07 PM
Dakkerz's Avatar
Dakkerz
Default Cusco A-Arm adjustment
I have the Cusco A-arms installed up front, but I dont have the original instruction sheet that came with it and would like to make some adjustments. Just wonding if anyone can help me out with either a picture of the preset camber adjustment diagrams or a link to a site with them (cusco's home page didnt help). Thanks in advance.
Old Oct 20, 2006 | 12:22 PM
1nate7's Avatar
1nate7
The arm pictured is set to the "0" position, which should be similar to stock. There is only 1 positive adjustment and 3 negative.
Old Oct 20, 2006 | 12:27 PM
Dakkerz's Avatar
Dakkerz
Yeah I have it at 0 now and want to set it to postivie but I'm not sure what exactly the bolt setup should be. Thanks for the quick reply though, I just need a photo of the positive setup now.
Old Oct 21, 2006 | 09:21 AM
1nate7's Avatar
1nate7
Looking at the pic, take out the top 2 bolts and bottom 2 bolts. The middle 2 can stay in, just loosen them up. Slide the adjustable section all the way to the outside of the arm and then put the bolts back in. 2 bolts will go in the holes all the way to the outside of the arm, the rest in the long middle slot. Hopefully that made sense.
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
