Koni Install On 2003 Help
Old Nov 7, 2006 | 03:36 AM
ZZZ-35's Avatar
ZZZ-35
Question Koni Install On 2003 Help
I started to install my new Koni stocks today on my 2003 Track, the rears went on without any problems but I've struck a problem with the fronts. It appears that the front Koni's are fatter in diameter by 5mm than the orginal struts fit to my car plus the bottom spring location plate is fixed to the strut and not removable as the instruction state that come with the Koni's, am I missing something here or did the Koni's only fit the later models.
Thanks in advance.
Old Nov 7, 2006 | 06:55 AM
jmark's Avatar
jmark
The Koni Yellows work on my 2003.
Old Nov 7, 2006 | 12:12 PM
arizzee's Avatar
arizzee
I also have Koni Sports (yellows) on my '03. Not sure if I understand the problem. Yes, the Konis are larger that the stock dampers but that's a good thing They fit fine. You shouldn't need to change the spring perch height. The Konis should have been packaged with spring perches that you need to slide onto the shock body. Maybe those are missing?
Old Nov 7, 2006 | 12:20 PM
ZZZ-35's Avatar
ZZZ-35
Many thanks, I got the Koni Sports s/hand and they did'nt come with the spring perches, problem solved, I will contact the previous owner.
Cheers
Old Nov 12, 2006 | 05:35 AM
AAB350z's Avatar
AAB350z
I just bought the koni sports and I was wondering how the rear shocks adjust? I noticed they don't have the **** inserts like the front shocks do.
Old Nov 12, 2006 | 05:42 AM
jmckuhen's Avatar
jmckuhen
Go to the bottom....figure 1
http://www.koni-na.com/adjustment.cfm
Old Nov 12, 2006 | 09:09 AM
andypandy's Avatar
andypandy
Thanks in advance.
on the yellows, the front shock body have 2 indents on them where you insert circlips (can lower or raise by an inch or so). if you are missing them, call koni and they will send them to you for free (they did to me after i busted one up). next, there are 2 chromoly steel spring perches (non-adjustable) that you lay onto those circlips. i hope this answers your question.
gl with install!
andy.
Old Nov 12, 2006 | 03:16 PM
ZZZ-35's Avatar
ZZZ-35
gl with install!
andy.
Thanks, which indent (circlip groove) is the std ride height.
Cheers,
Old Nov 12, 2006 | 06:48 PM
andypandy's Avatar
andypandy
if i can recall, the top is the standard shock height. i used the bottom indent and i am HATING it, as my front tires are tucked and the front bumper is dragging all over southern california.
kyin
Oct 15, 2015 05:54 AM
