Does a lower ride have to mean more uncomfortable?
HI all,
One of the things I love most about my Z is it's combination of comfort and performance.
Like many people here I would like to tune up my performance and the looks of the car but I don't want to turn my daily driver into a bone-shaking rattle box.
I'd like to fill out my arches and maybe lose 3/4"-1" in ride height to add to the asthetic of my ride while hopefully gaining a little extra grip without affecting the smooth ride and balance of the car. I'm currently on the stock 17's and Potenzas on my touring.
My goals in order of importance are...
1- Reasonably comfortable ride for daily driver
2- Road noise
3- Aesthetics
4- Improved Handling
5- Unsprung weight
Am I being reasonable or am I looking for qualities that are mutually exclusive?
Notion
2- Road noise
3- Aesthetics
5- Unsprung weight
Notion
In theory, lowering the car lowers the center of gravity. The car should handle better.
But theory does not always apply the real world. Check the autocross forum. Lowering the car is not a popular mod. Lowering the car would present other problems such as clearing suspension components and fenders while racing.
Yep it's nice to know I can get some 'low' from some reasonably priced springs without shaking out my fillings.
I think I'll wait to rims rubber and springs all at once hoping I can get away with some nice fat lipped 19's without adding pounds or busting the bank.
Notion
Notion
My Z actually road better with Eibach springs than it did with the stockers.
Our Z's are already low to begin with so lowering an inch or two won't drastically change your ride. Unless you decide to go with stiff and linear race springs/ coilovers theres not much that will jar you more than it already does now.
One must calculate the natural frequency* of the suspension to derive the harshness then select under, critical, or over damped to fine tune..........obviously this depends on tire compound temperature [stiffness] and will change as the tires change.
Body Acceleration vs settling time is the usual criteria if cost is not a factor
http://ocw.mit.edu/NR/rdonlyres/Aero...sp_optimiz.pdf
* the ratio of unmounted spring length to the compressed length with body on springs [as mounted].
http://www.smithees-racetech.com.au/...cefactors.html
http://phors.locost7.info/phors14.htm
http://phors.locost7.info/contents.htm
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
