what is Dampening Force?
Old Nov 9, 2006 | 10:56 PM
pushin 15 psi's Avatar
pushin 15 psi
Default what is Dampening Force?
i tried to search to see if anyone asked this question but came up empty handed so if this has been asked sorry. but i was just wondering what the hell it is. i like tein and it talks alot about dampening force. any help thanks
Old Nov 10, 2006 | 01:14 AM
GReddySetGO's Avatar
GReddySetGO
The stiffness of the damper. So if its adjustable, you can make it harder or softer. Non-adjustable is the same all the time.
Old Nov 10, 2006 | 06:10 AM
Q45tech's Avatar
Q45tech
A shocks dampening is expressed as slow and fast rebound [expansion] and slow and fast compression rates..................also these change with internal temperature of the fluid and anti foaming Nitrogen pressure.
pounds [or metric] vs speed of movement over a standard distance [1.0 foot or 0.3 meters per second]
Since shocks typically have only a +- <3.5" total movement range you must multiply the stiffness by ~~4x
The following will be helpful:
http://www.me.berkeley.edu/ME107B/sh...l_Pictures.htm
http://www.me.dal.ca/~dp_98_7/report/firstreport.htm
http://e30m3performance.com/tech_art...rear_shock.htm
Old Nov 10, 2006 | 10:57 AM
350Zteve's Avatar
350Zteve
Dampening force is how wet you get in the rain.
Damping force is the force the damper has to resist the motion of the spring.
Old Nov 10, 2006 | 12:56 PM
Q45tech's Avatar
Q45tech
Since the natural frequency runs 1-1.5 Hz [1second-0.66 seconds] ................the time is as critcal as the resisting force.
If you don't stop the oscillation at the natural frequency you get under or overshoot.............this the term under or over damped.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
