Rear tire feathering after spring install?
Old Nov 27, 2006 | 02:47 PM
slipslipslip's Avatar
slipslipslip
Default Rear tire feathering after spring install?
Well after i installed my rear hotchkis springs, i noticed the wheels go in at an angle. I thought an alignment would cure it, but no such luck. I'm not sure if I installed the springs upside down in the rear, would that be a possible cause?
If its not, is this something firestone (my alignment place) could fix? Or do i have to make a trip to the dealership. I'm assuming it won't be under warranty since its the spring install that caused it to go out of whack.
Old Nov 27, 2006 | 10:50 PM
showstoppertk's Avatar
showstoppertk
please do a search as this topic has been discussed to death. however to point you in the right direction. first off, what you described is not feathering. its just aggressive camber which will be followed by premature inner tire wear. if you've already don't an alignment, then what you need to do is purchase and install a camber kit. you should be fine with just a rear camber arm kit, I recommend the SPC version. after you get that installed then you should be able to get an alignment to correct your problem.
Old Nov 28, 2006 | 03:16 AM
FritzMan's Avatar
FritzMan
I find it to be more of a toe issue.
Get an alignement to make sure it's up to the latest spec.
Old Nov 28, 2006 | 07:27 AM
Q45tech's Avatar
Q45tech
Exactly to the exact midpoint of wide warranty range.......not just in the range.
hulkout
Apr 28, 2017 09:00 PM
bcoffee20
Nov 19, 2015 06:39 PM
Paul.
Oct 16, 2015 07:34 PM
kyin
Oct 15, 2015 05:54 AM
