Rear camber help! any suggestions?
Old Nov 27, 2006 | 09:28 PM
sk26dett's Avatar
sk26dett
Default Rear camber help! any suggestions?
Hello everyone, i need some advice on camber kits. I lowered my 03 Z on eibach sportline springs, but now the rear camber is way off, far more than i expected so it needs to be fixed asap. Does anyone have any advice on which camber kits are better or are they all the same? thanks for the help.
Old Nov 27, 2006 | 09:58 PM
JETPILOT's Avatar
JETPILOT
Go with Battle Version camber arms. They are the best. They use heim teflon lined end links. You wil lalso need to correct the toe as that will likely be out of spec as well and you will have exceeded the stock adjustability. You will need SPC toe bolts.
JET
Old Nov 28, 2006 | 12:06 AM
ProfessorKan's Avatar
ProfessorKan
subscribing^
Old Dec 2, 2006 | 12:29 AM
adrianko43's Avatar
adrianko43
The SPC rear camber arms seem to be the most popular on here, and they cost around $150. You should also get the SPC toe bolts as well.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
