Anyone rebuilt their Brembos?
I was going to do mine soon, since I went to the track alot this year and was curious to see what exactly I will need.
Thanks!
Thanks!
You will want to get your hands on new dust boots and seals in 38mm and 44mm sizes for the front and 40mm in the rear. You will need qty 4 of each sized dust boot and seal which you can order from us. Replacement bleed screws might also be something you might want to look at, or even something like speedbleeders if you need to do 1 man bleeds before or during a track day. I would recommend you stay away from pulling the caliper apart if possible since you might have some issues, although I have rebuilt the 2 piston rear brembos on my STI with no issues. There is an internal fluid passage that is sealed with a small o-ring that will need to be kept somewhere safe if you do take them apart.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
