350z unrevised springs,being replaced w/g35 cpe.rears????? HELP
Old Dec 11, 2006 | 05:16 AM
wreckeds2k's Avatar
wreckeds2k
Default 350z unrevised springs,being replaced w/g35 cpe.rears????? HELP
I am replacing my 350z unrevised with g35coupe rear springs. Is this gonna make it sit a lot higher? Does anyone have rates or meaurements? Or even pics of this being done. My Z springs have 2reds 1 white dot, my G's have 3red dots. Help or comments appreciated. All of this in comparison with revised springs.
Old Dec 11, 2006 | 06:40 AM
Gsedan35's Avatar
Gsedan35
Based on the color coding on the G35 coupe rear springs, IIRC they are not from a car with a sport suspension, so spring rate wise they are exactly the same (342lbs) as your oem unrevised rear springs. As far as ride height, I would expect +.5" Their will be no harm in running them, though I doubt you'll be pleased with the rear height gain. IMO, run them until you can source another set of 03/04 unrevised rears.
I take it that something happened to the original oem Z springs?
pdexta
Sep 14, 2015 11:27 AM
