Coilover Recommendation (Recent Tein Flex Owners?)
Old Dec 27, 2006 | 11:21 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Originally Posted by Z1 Performance
they do not include pillowball mounts, nor do they offer them - they reuse the stocker rubber upper mounts.
I've had both pillows and non in my own car (had Cusco with pillow and without and the HKS have them) - since camber is not adjustable at the pillow on this car in the first place, its by no means an essential must have thing IMHO, especially for a more street oriented car
What type of drop are you getting out of your RS's?
Old Dec 28, 2006 | 12:41 AM
636Racer's Avatar
636Racer
silkroad rm/a8
It isnt so hyped up like Tein or JIC, and IMO and experiences...the rm/a8 performs way better.
I was afraid of how they springs would affect street driving. Come to find, they're pretty street friendly at 10kg in front and 8kg in the rear, both rates are linear rates. All I have to do is bump up the preload some mm and tighten up the damping a couple clicks when I hit the track.
KW on the other hand, I've had experience with them in Porsches. They're very tight, and predictable. I drove 3 - 911, only two of them had KW and the other had H&R. The KW equiped cars were awsome, we noticed more fatigue in the H&R equipped car after long heats.
I hear stance is pretty good too. But I have yet to drive a car equipped with them. I hear even with their agressive spring rates, they're pretty good on the street. But for the track enthusiast...that doesnt really matter, does it?
Old Dec 28, 2006 | 01:41 AM
thawk408's Avatar
thawk408
Originally Posted by 636Racer
silkroad rm/a8
Ive done some research on this coilover and I have found that it has the exacty same spring rates and overall basic design as the Zeal function V6. This makes me wounder how similiar they really are. Could be a VERY good option for a fraction of the price of the Zeal's.
Old Dec 28, 2006 | 10:43 AM
636Racer's Avatar
636Racer
Which coilover are you refering to?
Old Dec 28, 2006 | 10:45 AM
Vq.turbo.DremZ
I believe yours? The silkroads.. Btw they are true coilovers in the rear correct? eliminating the need for the lower spring bucket (stock spring location, similar to the Stance setup)?
Old Dec 28, 2006 | 10:55 AM
636Racer's Avatar
636Racer
no, they're similar to stock. where height adjustment is still on the shock body and preload adjustment is above the spring in the stock location.
You can convert them to the conventional coilover as well. just specify the spring rate, and order extra locking collars and spring seats.
Old Dec 28, 2006 | 10:56 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the Flex adjustment range is so-so - not the greatest span IMHO
I am at 25.5 inches center line of fender well to pavement both front and rear on my RS
Have not tried the SilkRoads - sort of a west coast thing it seems with the 240 crowd
Old Dec 28, 2006 | 11:23 AM
636Racer's Avatar
636Racer
yah...there are a handful of drifters w/240s here that have them.
Old Dec 28, 2006 | 11:39 AM
thawk408's Avatar
thawk408
Yours
Old Dec 28, 2006 | 08:14 PM
Vq.turbo.DremZ
As of right now, i contacted a couple of local vendors and vendors on the site whether or not they can order a set of KW's or RS's. In all honesty i'm close to just saying F*** it and buy a set of tein basics...
Old Dec 28, 2006 | 10:02 PM
thawk408's Avatar
thawk408
Call that vender in the link i posted. Very nice people and gave me the best price around on the Variant 3.
Old Dec 29, 2006 | 07:05 AM
Z1 Performance
Former Sponsor
sounds like you're talking to the wrong people then
The HKS are not in stock with us at the moment - I'd have to see if HKS had any.
KW for the Z ship direct from Germany or KW's west coast office to the customer, depending where they are in stock - I doubt anyone sells them lower than we do, as we sell a large amount for Subaru and Evo's, and as such, our discount structure is more favorable than most. From Cali takes about a week, from Germany, between 3-10 days depending on inventory levels, etc.
Old Dec 29, 2006 | 08:00 AM
Vq.turbo.DremZ
Hey Z1, could i get a price quote then for the KW's shipped to 08648? I got a couple of price quotes from other vendors that's pretty cheap..
Also will i be able to order them from you with Linear springs? Will they have a price differance? Better off with Swift springs?
Tein Flex with custom springs a better idea?
Again thanks for all the help guys..
-Steve
Old Dec 29, 2006 | 08:10 AM
Z1 Performance
Former Sponsor
Yes they can be ordered with linear springs - linear springs cost around $100 or $120 per pair (have to double check what they are for the Z). These springs are supplied in addition to the progressive ones, they are not in substitution of. For more customized setups, they offer the race line which start at around the $3k range MSRP and go from there, and are a totally soup to nuts custom set based on your input. We do not offer Swift springs; KW supplies the linear springs directly. Personally, I would not bother upgrading to the linear springs until you spent some time with their out of the box setup, learned to use the various adjustments they provide, etc. At that point, you'll have a first hand knowledge base for what, if any, "wishes" you have, and you'll be in a more directly equipped position to decide what linear rates to get. Doing it before hand is nothing short of a guessing game that can get both expensive and time consuming.
Old Dec 29, 2006 | 08:18 AM
Vq.turbo.DremZ
Good point, ill have to try it out...
Price for a set of the KW's?
Old Dec 30, 2006 | 09:47 PM
Gsedan35's Avatar
Gsedan35
Adam, I want to chime in with a few points.
One, the front setup has a very small rate spread, only 35lbs. And that 35lbs, the front springs don't change rate with coil bind, so no sudden rate change. They are progressive because of how they change outside diameter top to bottom. Secondly, in order to have a true linear setup, KW would have to have a upper mount that will accept 65mm ID springs, not sure KW has such a upper mount or if they do that the cost could be justified, but that cost isn't for me to judge I know.
Secondly, looking at the rear springs, they use a wound coil that also changes diameter top to bottom, but vs the fronts the change is much more dramatic, hence the rear much more pronounced rate spread. Looks like 2.5" at the top to 5" at the bottom. Looks like the bottom of the spring is wound to sit in the oem location in the trailing arm the same way as the oem spring does. If that's the case, KW would have to have a lower perch that sit's in the oem location with the ablity to mount a 65mm ID spring. Thing is, in the pictures in the following thread, I cannot see how the rear spring looks or mounts to the lower suspension.
https://my350z.com/forum/showthread....w%2A+coilovers
In conclusion, I don't see the point in changing the fronts for such a small rate change that can't ever change suddenly by coil bind. Though in the rear, given the large swing in rate, that one I can see changing.
Old Dec 30, 2006 | 10:15 PM
Z1 Performance
Former Sponsor
agreed - and actually, they are not even supplying the V3's with alternate rates anymore. For a more customized setup built to user specs, they have a competition line of coilovers. For other cars, they also offer a Clubsport version as well (which use a linear spring), but not sure if they are doing those for the Z yet.
G35 - have you had a chance to go for a ride in a KW equipped car? Let me know where you're located, maybe I can arrange a ride for you. They have really worked out well for us so far, and if I had to do mine over again, these, Zeal or Ohlins would be on the short list.
Enjoy the New Years !!
Old Dec 31, 2006 | 08:03 AM
  #38
Vq.turbo.DremZ
Hey Adam, did you get a chance to drive/ride in the Stance equipped Z yet?
Insight in to other possible coilovers? I've seen quite of other choices, and at this point im open to everything. Cusco 1&2's, Ksport Pro, Greddy type-S, Eibach Pro-Street, H&R Street Performance, Tanabe Sustec Pro-Seven, and even Zeals to name a few, on top of my other selections.
Old Dec 31, 2006 | 08:16 AM
  #39
Jokestrap's Avatar
Jokestrap
I never hear anyone talk about the Greddy Type S Coilovers. SGP asked me to try them and I have had them for a 8 months and I love them. They are very adjustable and the ride is very close to stock with the right dampening adjustment. Then, with the turn of the ****, they get pretty aggressive. I highly recommend them. That's my $.02.
Old Dec 31, 2006 | 12:49 PM
  #40
Z1 Performance
Former Sponsor
no I have not had a chance yet - we;re a bit out east on LI and the one customer I know with them is in Queens so it's a matter of catching up at a meet or something. The one thing I do not like about them from a design standpoint is the rear does away with the standard spring location - there is alot involved in making that work correctly, and as such, I prefer to not reinvent the wheel and stick to how Nissan set the geometry up in the first place.
The Greddy's are quite nice, albeit a tad stiff. We've got a set going into Kwame's Z along with a whole host of stuff - look for a full write up once it's all complete, as we've got a large part of the shop with just his mods stacked up, ready to go on
Zeals are awesome, and we are the authorized dealer for the tri state area. Based on your initial posts I did not include them in my recommendations, as they are substantially more expensive than any of the others discussed so far (in the high $2k range)
