HKS Hipermax RS + Hotchkis sways
Old Dec 27, 2006 | 11:11 AM
Cloud's Avatar
Cloud
Default HKS Hipermax RS + Hotchkis sways
I just got them installed on my G35 coupe and I hear popping sounds in the back. Could it be due to the stiffness the sways introduced? Heard something about it being the crossmember.
Also, Today when turning onto the driveway, I heard the sound of a spring driver's side. I don't think that's supposed to happen. What could be wrong.
Old Dec 28, 2006 | 06:46 AM
tekk's Avatar
tekk
Not sure.. but if I set them to settings 17/30 - 26/30, I get squeaking sounds over any uneven surface.. if anyone has any experience with these coilovers please chime in...
Old Dec 28, 2006 | 08:19 AM
Cloud's Avatar
Cloud
I'm at 27/30 29/30
Old Dec 28, 2006 | 09:47 AM
12AutoX's Avatar
12AutoX
From my little knowledge of coilovers from my other car:
Spring sound (binding sound?) could be too much pre-tension set on the spring- try loosening the collar a little. Also, it's a good idea to wait a few days for everything to settle before making changes. I installed some coilovers for a 4.5" ride height, came back the next day and the car was 3.5" off the ground! Definitely wait a little while to get it aligned for the same reason.
Old Feb 15, 2007 | 11:34 PM
Cloud's Avatar
Cloud
my car is currently raised at its highest.... and I think there is binding sounds sometimes even when going in a straight line... What could be wrong?
Old Feb 15, 2007 | 11:54 PM
Cloud's Avatar
Cloud
I saw a video clip of a car with binding sound and confirmed that that is the sound that I've been hearing... So basically does this mean that my HKS Hipermax RS is raised too high?
it binds randomly though... many times it doesn't bind when i put alot of stress on one side of the car(cornering hard), and often times I hear the binding sound when going in a straight line or turning slightly....
Old Feb 16, 2007 | 10:30 AM
Axelerate's Avatar
Axelerate
The sound is from the metal top mount contacting the body and making noise. Some other coil-overs have this same issue. I think you can get some thin rubber and cut it the proper shape and make some DIY gaskets.
I have the RS's with the clunking but, it doesnt bother me. If you search you will see that some people fixed it with gaskets on top of the metal mounts.
Old Feb 18, 2007 | 10:39 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
My RS's are silent...they should not make noise, nor should rubber be needed anywhere
Old Feb 18, 2007 | 04:26 PM
Cloud's Avatar
Cloud
strange... according to infiniti techs they suspect that my left strut mount has a popping sound...
Old Feb 18, 2007 | 05:10 PM
Cloud's Avatar
Cloud
I read the installation manual again and could it be that the installer forgot to bend the installation tabs on the chasis as directed by the instructions and it comes into contact with the lls of the rear ride height adjustment collar?
hulkout
Apr 28, 2017 09:00 PM
RiujinZero
Sep 25, 2015 01:19 PM
