Ride height and weight loss
Old Dec 30, 2006 | 09:34 AM
teacher's Avatar
teacher
Default Ride height and weight loss
Not a big deal, but I`m wondering if anyone has an idea on this...
I`ve pulled weight out of my car:
1. pc680 battery
2. UR flywheel
3 Track rims
4. spare and jack
5. Ti single exhaust
-150lbs total
I`m happy with the results performance-wise, but the rear end seems to have risen a bit due to roughly 80 - 90lbs less weight from the axle back. No surprise there.
My rear tires are about 5/32, so the gap on the rears is a bit more pronounced on top of the lighter butt. So, I`m wondering about a gap-reduction. As it stands now I have an inch or a a bit more of gap in the front (with newer tires) and a full 2 inches or a tiny bit more in the rear.
I just received my TVS kit from Hotchkis, which luckily means the rear will be dropped a bit more than the front.
Question: Is there any way to ``settle`` the rear springs a bit more than the fronts? Perhaps sleep in the hatch for a couple nights?
Are there any other `tricks` to achieving more balance front-rear?
The weight will not be going back in, BTW.
I know the car will look good after the Hotchkis install - as it does now in a potato-digger kinda way.
Thanks!
Old Dec 30, 2006 | 10:44 AM
Kolia's Avatar
Kolia
You would need adjustable spring perches to lower the car.
Old Dec 30, 2006 | 07:36 PM
Gsedan35's Avatar
Gsedan35
You can adjust rear height by modifying the rear upper spring seats and adjust with self made lexan shims, or coil spring pads from energy suspension up to -.8"
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
ablaine
Nov 29, 2016 10:13 AM
