Why is the rear not lower w/Hotchkis springs?
Old Jan 12, 2007 | 07:43 PM
350Zenophile's Avatar
350Zenophile
Default Why is the rear not lower w/Hotchkis springs?
I had my Hotchkis springs installed a few weeks ago now (3) and immediately noticed the drop in the front but not the rear. I hear talk of allowing time to for the springs to settle on the forum, and also that good springs do not settle.
I was looking through the Factory Service Manual and came across the attached which shows my wheelarch height stock should be 681mm in the front and 700mm in the rear. I measured and I am at 665mm in the front and 700mm in the rear! Hotchkis lowers 15mm front and 19mm rear so the front is consistent but the rear didn't even move?
Any reason this may be? installer error?
File Type: pdf
Old Jan 13, 2007 | 12:49 AM
Chad68's Avatar
Chad68
I looked at your chart and the specs on the left side of the page,... those tire sizes are not Z tires sizes?? 225 and 235's??
I have no idea why your car didn't drop in the rear at all, other than maybe the installer didn't put the springs in at all or maybe he didn't seat them into the upper bushings correctly?
I'm actually going to hack off 1/2" off of my upper rear bushings soon to drop the rear 1/2" more, despite being informed it's not the best thing to do and I noticed that the springs need to fit into the upper bushings a certain way or it would give you a higher ride height.
Old Jan 13, 2007 | 04:20 AM
350Zenophile
LOL...I see you have a 2006. All base and enthusiast 2003-2004 Zs came with 17" wheels and tires. That is what is currently on my car.
The stock springs are black. The installed are clearly silver like the Hotchkis ones I purchased, however there are no other distinguishing marks.
I had the car jacked up last night to adjust the sways and took a look to see if they were seated correctly...kinda hard to tell on the one side but the other looked right. You could see the end of the upper spring coil sitting in a groove that ended in the same spot. Both sides measure the same height.
Could alignment be a factor here? I still haven't done that.
Old Jan 13, 2007 | 01:52 PM
Triple8Sol's Avatar
Triple8Sol
It def drops all around. I went from Z springs to the Hotchkis springs, and there was a noticeable drop all around.
Old Jan 13, 2007 | 01:55 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I'm not sure how somone is able to install spring incorrectly. That is where I'm confused at.
Old Jan 13, 2007 | 03:41 PM
350Zenophile
I know right? The rear doesn't seem difficult at all. The only reason I had the shop do it was b/c I didn't want to mess with the spring compressor for the front. Maybe I'll take apart the back myself tomorrow and see what's going on.
Robert, would you mind taking a measurement since your still on stock rims and let me know where you're at? thx
Old Jan 13, 2007 | 03:44 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well I have stock 18 inchers not 17s.
Old Jan 13, 2007 | 03:50 PM
350Zenophile
I know, but the FSM has stock height for the 18s with 245/45 tire you should be at 706mm rear. Hotchkis drops 19mm R for 687mm. If you are even close to that, I'll be taking my springs out tomorrow to take a closer look at what's going on. Not going to waste my time if you are closer to the 706mm.
Old Jan 13, 2007 | 08:11 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Id like to see pics of the car...
Old Jan 13, 2007 | 08:32 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
My car???
https://my350z.com/forum/south-west/242048-took-some-pictures-today.html
https://my350z.com/forum/brakes-and-suspension/241502-finally-pics-hotchkis-tvs-kit.html
Old Jan 13, 2007 | 10:27 PM
Chad68's Avatar
Chad68
Looking at the side pics it looks like you have a normal Hotchkis drop in the rear to me. It's a little hard because your car is black but The gap you have from the bottom of the fender to the top of the tire looks very similar to mine.
In fact with your taller sidewalls, it actually 'looks' lower than my gap possibly.
You have had the springs for like 3 weeks? But how many miles have you driven in that 2 weeks and on what kind of roads?
Try to drive down some crappy bumpy roads for a while and that may help them settle quicker.
All in all your drop looks fine by what I can make out in your pics.
Old Jan 13, 2007 | 10:29 PM
Chad68's Avatar
Chad68
Actually the pic in front of the Zoo looks lower than mine. In that pic your car looks totally level, which Is what I'm trying to get mine like. I think the difference I'm seeing is in our tires sizes.
I think your drop in where it's suppose to be.
Old Jan 14, 2007 | 01:13 AM
Chad68's Avatar
Chad68
I wrote:
*** I noticed that the springs need to fit into the upper bushings a certain way or it would give you a higher ride height***
I take that back. There is no specific way they go in. When I was looking at my bushings they looked like the springs had to go in a certain way but it's just because the bushings were mushed down.
Old Jan 14, 2007 | 02:13 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Chad: Those are pictures of my car not the OP. LOL
Old Jan 14, 2007 | 03:02 AM
Chad68's Avatar
Chad68
Really? Oh I knew that, I was just testing you guys
No wonder it looked so good
Old Jan 14, 2007 | 08:13 AM
350Zenophile
Before Hotchkis:
Attached Thumbnails Why is the rear not lower w/Hotchkis springs?-img_0063.jpg
Old Jan 14, 2007 | 08:14 AM
350Zenophile
After Hotchkis:
Attached Thumbnails Why is the rear not lower w/Hotchkis springs?-img_0002.jpg   Why is the rear not lower w/Hotchkis springs?-img_0003.jpg   Why is the rear not lower w/Hotchkis springs?-img_0008.jpg   Why is the rear not lower w/Hotchkis springs?-img_0009.jpg
Old Jan 14, 2007 | 08:16 AM
350Zenophile
Hotchkis rear springs in their seats:
Attached Thumbnails Why is the rear not lower w/Hotchkis springs?-img_0010.jpg   Why is the rear not lower w/Hotchkis springs?-img_0011.jpg   Why is the rear not lower w/Hotchkis springs?-img_0012.jpg
Old Jan 14, 2007 | 11:18 AM
350Zenophile
Took the wheel off to get a better shot. Is the red dot supposed to be on the bottom or top side? Looks like the spring is sitting in the seats properly?
Attached Thumbnails Why is the rear not lower w/Hotchkis springs?-img_7.jpg
Old Jan 14, 2007 | 11:21 AM
350Zenophile
more pics:
Attached Thumbnails Why is the rear not lower w/Hotchkis springs?-img_3.jpg   Why is the rear not lower w/Hotchkis springs?-img_5.jpg   Why is the rear not lower w/Hotchkis springs?-img_6.jpg
