espelir active gt
Old Jan 16, 2007 | 09:39 PM
wesismyhero's Avatar
wesismyhero
Default espelir active gt
does anybody have them? how is the ride harshness? would you reccomend them or get something else?
Old Jan 17, 2007 | 06:37 AM
turbogsr10's Avatar
turbogsr10
I have them. Ride is pretty good, better than stock. I'd recommend them. The only thing I don't like is that they don't drop the rear enough.
Old Jan 17, 2007 | 08:39 PM
wesismyhero
i'm trying to keep drop to a minimum cause i'm getting 18s. it's either espelir or tanabe nf.
Old Jan 17, 2007 | 09:35 PM
Gsedan35's Avatar
Gsedan35
You won't be keeping your drop to a minumum with Tanabe NF's (or GF's for that matter)
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2”
Spring rates in LBS 314/353
Your minimum drop choices are
Tein H-tech 350z linear springs .3”/.2”
Spring rates in LBS 358/375
Espelir 350Z progressive springs .4"/.4"
Spring rates in lbs 386/515 (peak rates, initial rates are unknown)
RSR 350Z linear springs .6”/.6” (may be hard to find, Ti set on ebay now)
Spring rates in LBS 345/417
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6”
Spring rates in lbs 386/402 (final rates only, softer initial front progressive rate unknown)
Hotchkis 350Z Linear springs .6”/.8”
Spring rates in lbs 340/330
Swift 350Z linear springs .8”/.6”
Spring rates in LBS 336/364
Old Jan 18, 2007 | 02:19 PM
wesismyhero
i'll prob go with espelir or swift then. a friend of mine has teins on his sr 240 and he hates them.
Old Jan 18, 2007 | 02:28 PM
mdracer76's Avatar
mdracer76
Don't forget about the Espelir "Active Super Down" spring set
Old Jan 18, 2007 | 02:42 PM
changsw's Avatar
changsw
i have them, have had them for about 6-8 months now. i'm still using my stock shocks, which i think i should replace right about now, but what the hell. i don't have the money right now for new shocks.
but to answer your question, i don't think they are bad springs. they lower nicely (not too much). the ride quality is a little stiff in my opinion, but it's not that bad because it's expected when you lower your car right? anyways, i hope that helps. good luck!
Old Jan 23, 2007 | 03:29 PM
ke0ki2k's Avatar
ke0ki2k
arent the Active GT's like performance/handling springs ? id say theyd be pretty harsh & wont lower the car much...they'll be stiff tho...improve handling alot
Old Jan 24, 2007 | 09:26 AM
Gsedan35's Avatar
Gsedan35
They lower the car .4" They use higher then normal peak spring rates, but trade performance and peak handling because they are progressive with wide rate spreads (given the number of coils that bind).
Espelir 350Z progressive springs .4"/.4" (10mm)
Spring rates in LBS 386/515 (softer inital rates unknown)
Workshop12
Mar 23, 2020 01:45 PM
A_MEISTER
Suspension
Oct 25, 2015 04:50 PM
D_Rod
Sep 29, 2015 04:42 AM
doublej32
Wheels Tires
Sep 25, 2015 05:05 PM
jlc280z
Sep 24, 2015 08:43 AM
