with 19", need new suspension?
Old Jan 22, 2007 | 06:12 AM
nickatzou's Avatar
nickatzou
Question with 19", need new suspension?
Hello, I just put 19 inch rims on my 350z (19x9F 19x10R Racing Hart CR multipiece) and noticed that my car now wobbles when taking turns at high speed and when i hit a small bump on the highway. I would like to know if i can eliminate this problem with just lowering springs or do i need full suspension?
Old Jan 22, 2007 | 06:29 AM
bb1314's Avatar
bb1314
da Terminator!
Hmm... I think it's in your head or you're not understanding something. Getting bigger rims than stock won't affect your suspension. The ride is probably just more bumpy now since you went with bigger rims and lower profile tires.
Old Jan 22, 2007 | 06:43 AM
Zerk's Avatar
Zerk
Sounds like you may have a camber/toe issue. Sometimes if you go to a larger wheel this happens. If the toe is not aligned then your car would be all over the road. Maybe you should get an alignment.
Old Jan 22, 2007 | 08:29 AM
hardrock905's Avatar
hardrock905
I don't think larger wheels would cause a camber/toe issue.
It may make the issues more noticable tho.
If your wheels are truly "wobbling", you better check your lug nuts.
Old Jan 22, 2007 | 12:51 PM
z-u-later's Avatar
z-u-later
You need to re-torque your lug nuts to make sure they did not loosen up after the initial install. You always want to do this whenever you have taken off the rims and driven a few miles.
350Z_Al
Oct 29, 2020 07:44 PM
pr_350z
Oct 1, 2015 05:03 PM
