Lowering spring = zero wheel / fender gap
Old Jan 24, 2007 | 12:31 AM
InZpire's Avatar
InZpire
Default Lowering spring = zero wheel / fender gap
Are there springs out there that cancels out the gap? Like almost no gaps at all.
Old Jan 24, 2007 | 01:42 AM
Mazinger Z's Avatar
Mazinger Z
There are pretty low ones...Tanabe NF210's come to mind...also you can try some coilovers - my friend has the JIC FLTA2 and you can go pretty low with that. Keep in mind you will need to get front and rear camber arms if you plan to go looow...
Old Jan 24, 2007 | 09:03 AM
Gsedan35's Avatar
Gsedan35
Do that and you'll want shocks that have shorter bodies and piston rod lengths too (sadly, no one does except maybe TcKline), unless no bump travel doesn't matter. Coilover's, especially one's with full height adjustablity are a better choice for this reason.
Old Jan 24, 2007 | 08:44 PM
InZpire's Avatar
InZpire
Thanks guys!
Might just save up for the tein basics since i still have to get those f+r camber arms.
Old Jan 24, 2007 | 09:03 PM
NX ZR's Avatar
NX ZR
i have Tanabe NF210....almost 1 1/2 inch drop front and back......
Axis Matrix 20x9 with 245/35ZR20 Nitto INVO (front)
Axis Matrix 20x10.5 with 285/30ZR20 Nitto NT555 (rear)
no wheel-gaps, no fender-rub.....it's perfect!!
i'll try to post some pics later!!
Old Jan 24, 2007 | 10:36 PM
InZpire's Avatar
InZpire
^^ Please do!
Old Jan 27, 2007 | 01:49 PM
workseuge's Avatar
workseuge
go with the eibach sportlines...i dont have a gap and i luv the ride
Old Jan 31, 2007 | 12:34 PM
AroundMyHorn's Avatar
AroundMyHorn
do you need camber kits with the tanabe's or eibachs?
Old Feb 2, 2007 | 11:17 PM
InZpire's Avatar
InZpire
Do you have pics of the car? Looks promising!
