Question about spring/dampener install?
Old Feb 10, 2007 | 07:53 AM
plumpzz's Avatar
plumpzz
Default Question about spring/dampener install?
I just purchaced tokiko springs and dampeners. I wanted to know if the install can be done by a regular tire and alignment/suspension shop instead of a performance shop. I want to know if it is any different than an OEM style install? Basically, could a regular shop do it.
The shop is very good and professional and they even have a laser guided alignment tool in the shop so I thought it'd be a good idea to get it done at the same place. They also charge significantly less than race shops. I had my wheels mounted and balanced there and they were very careful not to scratch anything too!
Old Feb 10, 2007 | 08:13 AM
Nihilation's Avatar
Nihilation
You should at least do the rears yourself. It's very, very easy and will save you a little bit of labor since they'll charge you for only the front install.
Any shop that has a spring compressor should be able to do this. Some people have done the install without a spring compressor.
Old Feb 10, 2007 | 09:35 AM
plumpzz's Avatar
plumpzz
Im too lazy, its too cold. The 50 bucks ill save isnt worth it to me. Besides, you pay the premium for a warranty on the labor. Otherwise, I'd do everything myself. I have the tools for it.
But thanks, as long as I know any shop can do it, then Ill go for it.
Workshop12
Mar 23, 2020 01:45 PM
TrackFiddy
Sep 24, 2015 11:40 PM
Suffolk350z
Sep 13, 2015 02:43 PM
