GT Spec Rear Braces: Bolts Too Short
Old Jan 15, 2008 | 09:11 PM
SpoilsofWar's Avatar
SpoilsofWar
No issues with installing any of my GT spec bars, with the stock bolts.
Old Jan 16, 2008 | 02:53 AM
NCPG's Avatar
NCPG
Originally Posted by Asterix
Minimum thread is easy: as much as the diameter of the bolt. For example, a 8mm bolt with 1.25mm pitch threads needs 8/1.25 or 6.4 turns. M12x1.75 needs 12/1.75 or 6.8 turns. Measure the bolt and you'll know. It also tends to be the thickness of the nut.
Asterix
Thanks. I'm not certain of the diameter of that bolt. I had heard that '08 Pathfinders used a similar, but longer bolt. I have not been able to confirm that. If so, that would be a solution.
Old Jan 16, 2008 | 12:21 PM
MustGoFastR's Avatar
MustGoFastR
I have my front and rear tie bars on with no washers and no issues. I don't see the point of those thick-@ss washers.
I'm about to pick up the V2 rear lower tie bar, since it is finally available and I don't plan on using the washers for it either. The issue of the nolts being too short has bee around as long as these bars. Some guys just don't run the washers, others use them and just deal with the nut not grabbing all the threads and they have not seemed to have any issues.
Old Jan 16, 2008 | 06:36 PM
wesismyhero's Avatar
wesismyhero
I have the rear lateral bar, no problems here.
Old Jan 17, 2008 | 03:00 AM
NCPG's Avatar
NCPG
I was told that the washers keeps the harder nut from galling the softer metal of the brace, as the nut is torqued down.
Maybe someone should market the longer bolts, based on a greater strength (more threads engaged) and margin of safety. In every picture I've seen on this site of the installed rear braces it appears that only about 1/2 the threads on the nut are engaged. I don't know how many turns (revolutions of the nut) that represents, but I wonder if that gives sufficient factor of safety.
Old Jan 17, 2008 | 04:13 AM
Greg'Z33's Avatar
Greg'Z33
Which bolt on the '08 Pathfinder, i.e. where on the body is it? I can get the '08 Pathfinder part number that way for you.
Greg
Old Jan 17, 2008 | 04:44 AM
Asterix's Avatar
Asterix
For all your nut and bolt questions, everyone should buy a copy of Carroll Smith's "Nuts, Bolts, Fasteners and Plumbing Handbook". There's lots of good information in there and it's even easy to read.
If there are at least three turns into the nut, you're probably fine. I wouldn't feel comfortable with that, but that's just me.
The washer is indeed there partly to keep the softer metal under the nut from being crushed.
Asterix
Old Jan 17, 2008 | 06:58 PM
jdepe's Avatar
jdepe
does anyone have gt spec rear tie bar and tried to use the spc toe bolts? or vice versa? because i have the toe bolts installed but now the bolts are way too short to be able to put the brace on.
Old Jan 17, 2008 | 10:27 PM
jining's Avatar
jining
what do you mean way too short? The bolts are maybe 1/4 inch too short to acommidate the entire nut, is that what you mean?
Old Jan 17, 2008 | 11:35 PM
jdepe's Avatar
jdepe
i ment that the spc toe bolts aren't long enough. like i cant use the spc toe bolts and put on the gt spec rear tie bar at the same time
Old Feb 11, 2008 | 05:30 AM
reptile718's Avatar
reptile718
Just installed the rear tie bar with no problems.
Those washers are a joke. They are the same size as the nut so I saw no point in installing them.
I had read this thread prior to the install and worried about the nut not being completely on the bolt. This can cause problems down the road. Without using the washers and torquing the nut to spec it fit completely on the bolt.
I drove to work this morning, about 30min on bad NC roads and took a look, everything looked great.
Old Oct 14, 2008 | 07:46 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
So has anyone used the SPC toe bolts and the GT Spec bar together yet? Does the GT spec bar need modifying?
Old Oct 15, 2008 | 12:35 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
So nobody has a GT Spec brace and adjustable toe bolts?!? I find that hard to believe.
Old Oct 2, 2010 | 11:32 AM
Spoiled Z's Avatar
Spoiled Z
I bought the megan toe brace and with the washer in place its definately short. I took it to oreilly's no luck. I have the locking nuts on there because I bought the circuit sport toe arms (bucket delete) and dont want to get rid of that. I think Im just gonna sell if the brace if I can't find a longer toe bolts.
Old Oct 4, 2010 | 08:36 PM
Row2K's Avatar
Row2K
^ holy thread revival Batman !
Old Oct 4, 2010 | 08:41 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
hmmm so is this a constant problem with rear braces? I was thinking GT spec or megan racing but idk now
Old Oct 4, 2010 | 09:15 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
I'm using the SPC toe bolts, and the GT Spec brace, and i haven't had a problem. The bolt was only just long enough, but it worked.
I've tracked the car at least half a dozen times since, and no problems so far.
Old Oct 5, 2010 | 07:40 AM
  #38
JasonZ-YA's Avatar
JasonZ-YA
If you make your own lock out washers you can use bolts that are longer........
LOCK OUT WASHERS:
https://my350z.com/forum/8293615-post20.html
REAR CAMBER:
at the camber arm location, if you have a brace there, you can use lock out washers, if you have an adjustable camber arm.
REAR TOE:
at the toe (spring bucket) you cant unless you have spl's midlink to adjust toe.
Toe arms (spring bucket delete) IF you have true coilovers.
OR,
NISSAN SUV/TRUCK SPC BOLTS:
you can go to O-reilly, and buy SPC toe bolts for a Nissan Titan, frontier or Xterra...
trace the eccentric over and get your dremel out and make the eccentrics on the trucks listed match down to the size the Z needs..
these bolts are way longer and will work, but will need to cut them down. to cut them, put a spare nut on first, then cut, and back the nut out to "fix" the thread end....
have fun...
-J
Old Oct 6, 2010 | 03:51 AM
  #39
cbcm2435's Avatar
cbcm2435
[QUOTE= to cut them, put a spare nut on first, then cut, and back the nut out to "fix" the thread end....
have fun...
-J[/QUOTE]
thats a good idea, ill have to remember that trick next time i have to cut bolts down, sure beats fixing them with a file
Old Oct 6, 2010 | 04:47 AM
  #40
JasonZ-YA's Avatar
JasonZ-YA
yea, if room allows, its good to thread two nuts on...use a die grinder to cut the bolt down, using the first nut as a guide, for straight cut, then remove them both and threads fix themselves...
-J
