lowering an 1in front and 1.2in rear
Old Mar 19, 2007 | 11:27 AM
TuscaniJon's Avatar
TuscaniJon
Default lowering an 1in front and 1.2in rear
I just got tanabe gf210 springs and will be doing an install soon, I know I will need an alignment but can I still be in spec with this drop? or would I need rear camber arms?
thanks
Jonathan
Old Mar 19, 2007 | 04:40 PM
TuscaniJon's Avatar
TuscaniJon
anyone?
Old Mar 19, 2007 | 10:01 PM
Gsedan35's Avatar
Gsedan35
thanks
Jonathan
With a 1.2" drop you won't be in spec.
How far your out of spec will dictate if you can justify the cost to correct. If your going to only correct the rear you should consider getting the SPC kit with arms and elongated toe cam bolts since changing camber also effects our toe.
Old Mar 20, 2007 | 12:24 AM
350ztoronto's Avatar
350ztoronto
iirc any drop over .05 inch you will not be in spec
Old Mar 20, 2007 | 08:07 AM
Gsedan35's Avatar
Gsedan35
Originally Posted by 350ztoronto
+1
iirc any drop over .5 inch you will not be in spec
In light of watching the subject since early 2003 here and on other Z forums, the average Z dropped to .8" can see it's alignment specs fall within oem specs. Most RSR, S-tech, Hotchkis, Swift, and S-tune owner's are able to get back to within oem specs.
Beyond .8" is where the law of averages among car's that have been on the rack and checked most often are out of spec on at least one end of the car if not both. And then it becomes are case of how far out you of spec you are vs the cost to correct vs how how much you think those specs will effect your tire wear.
Old Mar 20, 2007 | 11:10 AM
Elohite's Avatar
Elohite
I recently did the same thing. I am slightly ouot of spec. I will just rotate my tires when i sense some wear. let me know if you want to see it and i may scan my alignment spec sheet
Old Apr 4, 2007 | 07:48 AM
ZLadie2000's Avatar
ZLadie2000
I am thinking of getting Tanabe GF210 on my 07...is it true the 06 and 07 is not as low as the 2003-2005 so the drop wont be as noticeable as the 03-05 drop? I dont want to get Tein S Techs on my 07 and not notice a difference, ya know? My main goal is to improve handling and looks, and I want a stiffer suspension, steering wheel feels sloppy now.
I liked the Tein S Tech on my 04 but wont get them if I wont notice much of a difference on my 06. I love the drop on the Tanabe GF210 but dont want to have to get a camber kit and have tire wear issues.
Help? I need to make a decision soon...
Old Apr 4, 2007 | 10:01 AM
Gsedan35's Avatar
Gsedan35
No, oem ride heights are all the same. Oem tire sizes can play with the numbers as seen in the FSM (Factory Service Manuel).
The GF210's will lower more then the S-techs. But they are softer springs and they are progressive, which won't work to to excise the steering wheel slop you say you have now, nor will they feel as stiff as the S-techs.
Your oem setup now has the following stiffness on linear springs.
314/427 (do not look so hard at your rear oem rates as much as the front rate)
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Tein S-tech 350Z springs .7“.6“ (fronts are progressive, rears are linear)
Spring rates in LBS 386/402
Notice the number of closely spaced coils in this picture of GF210 350Z springs. These springs will have a wide spread between their published peak rates above and the softer inital rates courtesty of all those closely spaced coils.
Look for the same thing in this picture of S-tech 350Z springs. Notice that the front springs are progressive. BUT, only 1 maybe 1.5 coils will bind to effect rate change. Rear's are of linear.
If you have to have a 1" drop amount and your only wanting to be on shocks and springs and your still interested in performance, IMO the Tokico shock and spring setup is the way to go.
Tokico D-spec shock & spring package
350Z - DSK512 - 375f/375r - Linear Springs 1"/1"
Old Apr 4, 2007 | 12:00 PM
ZLadie2000's Avatar
ZLadie2000
So your saying if I'm more performance oriented I should go with the Tein S Techs over the Tanabe GF210? I just want a decent drop but better handling because I will be road racing the car...in about 10 days. Thanks.
Old Apr 12, 2007 | 10:21 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Every place that list the specs are as follows.
Tanabe: Sustec GF210
Type: Linear
Front Rate: 6kg/mm (335lb)
Rear Rate: 6.7kg/mm (374lb)
Front Drop: 25mm (1in)
Rear Drop: 30mm (1.2in)
Where are you getting your info on the GF210s being progressive?
edit: after further research I really don't know if you can catergorize them as one or the other.
Here's a post I got from Revolution Motorsports
Originally Posted by Revolution Motorsports
Heres the low-down on springs, coilovers, struts, etc.
The Gf210 cil spring is geared more towards performance and track use due to its more linear rates and higher spring rate, but is completely suitable for daily driving.
Regarding progressive and linear rates, there is a lo of misinformation on the internet as to what is better, why and what to look for. Many people tend to ask "Are they progressive or linear?" For a standard coil spring that mount to OEM style shocks and struts, they cannot be one or the other.
Standard automotive coil springs (with the exception of fixed diameter springs for adjustable coilover suspension) are both linear and progressive. For drivability and ride cumfort, a portion of the spring uses a progressive rate, while the majority is linear.
Old Apr 12, 2007 | 03:57 PM
Saikou's Avatar
Saikou
I have almost the Same exact Issue, I also have a 2007 350z and i am looking to have a decent drop I am thinking of getting the Tanabe GF210's.
But i am not looking to improve the handling of my car,seeing as my it will be used as a daily driver and not on the track. So the GF210's seem like the best springs for me, but i am worried about having to get a camber kit, which i would like to not purchase seeing as they are much more expensive than the springs themselves.
So my real question is....Is it necessary to purchase a after market camber kit for a 350z in order to install the Tanabe GF-210's and archive the 1.2inch drop. W/o having to deal with all the problems with alignment that i have heard?
Note: i have called several shops how much it would be to install springs and one very meticulously cautioned me about lowering the 350z more than 1inch and warning about all the problems i will have and how it is a must to purchase camber arms as well. This really had an effected on me and now Im rethinking wither i should lower my car at all.
Second note: he mentioned it was for an 05 350z
THANK YOU SO MUCH IN ADVANCED FOR YOU HELP !!
Old Apr 12, 2007 | 08:16 PM
dutchboy350Z
Finally some go
^ you'll definitely need a camber kit unless you want to go through rear tires every 10K miles.
Old Apr 13, 2007 | 03:14 PM
Saikou's Avatar
Saikou
so only a rear camber kit is needed? And if i were to get coilovers and adjust them so that they are still in spec. (such as only droping it 1inch) instead of getting springs would that allow me to to keep the OEM cambers? b/c it would be about the same price just to buy the tien basics instead of the springs +the rear camber kit.
thanks
Old Apr 13, 2007 | 09:06 PM
dutchboy350Z
Finally some go
thanks
Coilovers or springs if your drop is still in the 1 inch range you're going to need a camber kit to keep a near OEM camber in the rear.
Justin100
Nov 25, 2021 06:26 AM
