Factory Alignment Specifications - 2005 350Z?
It's the same as the 03 and 04:
Wheel Alignment (Unladen)
Camber
Degree minute (Decimal degree)
Minimum - 1° 20′ (- 1.33°)
Nominal - 0° 35′ (- 0.58°)
Maximum 0° 10′ (0.17°)
Left and right difference 45′ (0.75°)
Caster
Minimum 7° 25′ (7.42°)
Nominal 8° 10′ (8.17°)
Maximum 8° 55′ (8.92°)
Kingpin inclination
Minimum 4° 20′ (4.33°)
Nominal 5° 05′ (5.08°)
Maximum 5° 50′ (5.83°)
Total toe-in Distance (A - B)
Minimum 0 mm (0 in)
Nominal 1 mm (0.04 in)
Maximum 2 mm (0.08 in)
Camber
Caster
Kingpin inclination
Minimum 0 mm (0 in)
bcoffee20
Nov 19, 2015 06:39 PM
