SQUEAK SQUEAK!!! Can it be Suspension??
Old Mar 27, 2007 | 07:59 AM
asp17's Avatar
asp17
Default SQUEAK SQUEAK!!! Can it be Suspension??
I am starting to hear a squeaking noise from the rear when I drive. It seems to happen at bumps in the road. Can it be time for some new suspention components or maybe somethings loose (I HOPE NOT LOL) like the exhaust???
Old Mar 27, 2007 | 08:00 AM
Fluid1's Avatar
Fluid1
Did you even inspect anything?
Old Mar 27, 2007 | 08:21 AM
asp17's Avatar
asp17
I just noticed it this morning. Did a walk around the car and everything looks like its all screwed togather LOL. I gotta take it in this week for brakes so maybe have a pro look at. But some of these "PROS" just wanna make $$ and BS too much
Old Mar 27, 2007 | 08:24 AM
Jay'Z's Avatar
Jay'Z
u spelled suspension wrong....
Old Mar 27, 2007 | 08:27 AM
ldawg32's Avatar
ldawg32
and together as well. what was the highest level of education you received? lol j/k yeah let them check it out when you get your brakes done IMO
Old Mar 27, 2007 | 08:49 AM
asp17's Avatar
asp17
EDUMACATION?? WHATS THAT?? LOL
I just made an appointment with the car doc for today. Let see what it can be
Old Mar 27, 2007 | 08:52 AM
ecorona6's Avatar
ecorona6
Could be the brakes...My rears went before the fronts....
Old Mar 27, 2007 | 08:58 AM
asp17's Avatar
asp17
BRAKES?? Really they can make a noise just when going over bumps and dips on the road. I DO NEED BRAKES PRETTY BAD
I just thought brakes would more constantly squeak like when you are applying brakes
Old Mar 27, 2007 | 09:03 AM
bbs350z's Avatar
bbs350z
wd40 that muthaf@cka.
Old Mar 27, 2007 | 09:08 AM
asp17's Avatar
asp17
LOL
FUNNY
But it does work (not on the brakes) I had a old 95 Ford and I used to go through 2 cans of that a month just spraying the truck because of all the things that used to rattle and squeak!! LOL - NOT AGAIN!
Old Mar 27, 2007 | 09:14 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
do you have aftermarket suspension??? sway bushings could need lubricated, axle click, exhaust etc.
Old Mar 27, 2007 | 09:23 AM
asp17's Avatar
asp17
All OEM suspenSion
Like your car i have the same color
Old Mar 27, 2007 | 09:26 AM
imntcrzy's Avatar
imntcrzy
i've been hearing some squeeking coming from the rear compartment as well. Happened a little after I hit 75,000 miles. The squeeking is not muffled so it almost sounds like its coming directly from the rear hatch area.
Old Mar 27, 2007 | 10:03 AM
ARMSTRONGARMS
Originally Posted by asp17
All OEM suspenSion
thanks have you had the axle click tsb done??? mine did it over bumps? try spraying some wd40 on the exhaust hangers???
Old Mar 27, 2007 | 11:38 AM
asp17's Avatar
asp17
Have dont that TSB ill try that
Old Mar 29, 2007 | 06:38 AM
flintgauge's Avatar
flintgauge
What...?
Old Mar 29, 2007 | 09:50 AM
bbs350z's Avatar
bbs350z
^+12
Old Mar 29, 2007 | 11:22 AM
asp17's Avatar
asp17
Exhaust it was!!!! Tried to spray WD40 but it still made a little noise had to get the hanger welded at a shop. Seems to drive fine now for the last few hours
350Z_Al
Oct 29, 2020 07:44 PM
pr_350z
Oct 1, 2015 05:03 PM
