Tein Basic ride height...
Old Apr 17, 2007 | 01:41 AM
Dubai's Avatar
Dubai
Default Tein Basic ride height...
whats the lowest drop the basic can go? and can you set it to stock height?
I know its a good coilovers for dialy use. is it any good for track and autox?
Z1 Performance? Gsedan35? you guys are experts..
Old Apr 17, 2007 | 06:49 AM
Gsedan35's Avatar
Gsedan35
http://www.tein.com/nissan.html
As their web site show's. Yes you can setup to oem ride height.
Recommended (they've told me that they corner weigh at the recommended settings) 1"/.8" drop
Min Drop and max spring preload setting
.0"/+.1"
Max Drop and min preload setting
2.4"/1.1"
Reading between the lines, that means you are dailing in a lot of spring preload to get to oem height, in the front that is. Ideal spring preload is the minimum amount required to keep the spring seated when the suspension is unladen.
Old Apr 17, 2007 | 08:04 AM
Gooey's Avatar
Gooey
what does that mean in english?
Old Apr 17, 2007 | 09:20 AM
Gsedan35's Avatar
Gsedan35
That he can set them up to oem ride height, but Tein recommends a lower setting.
What too much spring preload "might" cause. "Might", as in maybe, maybe or maybe not. It's that "maybe" part and what might happen that makes minimum spring preload settings the ideal setting.
Harsh over small bumps (but spring never binds itself)
Wheel chatter over small bumps during braking
Not using full travel, feels harsh, poor corning and braking traction (caused because the spring itself runs out of travel or binds, I'd be shocked if that's possible with the basic setup however)
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
