Front Camber Kits to fix feathering..
Old Apr 24, 2007 | 11:01 AM
Q45tech's Avatar
Q45tech
The feathering is an issue [to varying degrees] on all vehicles [from every manufacturer on Earth] with excessive camber and caster where owners do not frequently rotate directional tires.
So very very common that they make expensive machines just to measure and profile it:
http://www.bytewise.com/products/CTWIST/default.html
Wear Pattern Name: Heel / Toe Wear
Characteristics: Comparatively rapid wear on the trailing edge of each tread block compared to the leading edge. Tread shoulders usually the worst affected.
Possible Causes: 1. A common wear pattern on aggressive block-type tread patterns that are used extensively on sealed roads. Caused by block flex. 2. Pressure errors. 3. Wheel-alignment errors. 4. Consistent, severe cornering.
Remedy / Action: Severity often decreases as tyres wear. 1. Reversing the direction of rotation will flatten un-even wear. 2. Replace tyre if tread depth is less than 1.6mm on any part of the tread. 3. Reduce turn-in speed when cornering.
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
