Tein EDFC...help
Old Apr 29, 2007 | 08:51 AM
Nismo G's Avatar
Nismo G
Default Tein EDFC...help
How is it going guys? I am a member over at g35driver, but with more active memebers here i figured i would post.
I am installing the EDFC motors on each strut and im trying to see if anyone had problems with the front motors? The rear ones went on easy with no problems, but the front motors seem as though for some reason there are different specs that are not listed in the directions. The screw that you turn ontop of the motor during the instalation will turn 3 times fine, then the actual motor will hand tighten, but when you go to turn the hex screw 2 more times...it will only turn 1 time...?
Any information would be great!
-Sean
Bodyboarder81
Nov 2, 2015 12:17 AM
failsafe
Apr 23, 2003 11:38 AM
robertchen
Nov 13, 2002 07:41 AM
