Coilovers
Old May 19, 2007 | 11:52 PM
DJames's Avatar
DJames
Default Coilovers
Maybe someone can point me to the right direction or the right setup.
I am looking for better handling. I want to see/feel a night and day difference. I like to take corners hard , i would like to be able to have a setup where it is perfect for Track and Street. I was thinking Stance GT+ / JIC / HKS . If these aren't it then please let me know what to get. I am also going to be getting Hotchkis Sways.
Old May 20, 2007 | 01:17 AM
JETPILOT's Avatar
JETPILOT
Stance true coilovers in the rear are the way to go.
JET
Old May 20, 2007 | 09:36 PM
DJames's Avatar
DJames
Any other input ? what do you guys think about the KW v.3 's ?
Old May 22, 2007 | 03:24 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. get good tires
2. get a good alignment
3. define what "track" means to you - does that mean 1-4 club days a year or are you building a race car. Then reasses how much "track" you are going to do, vs driving to get coffee and run errands
4. define your budget
Old May 22, 2007 | 03:28 PM
Gary King's Avatar
Gary King
I'm running them with Eibach Sways and love them. Great at track days and daily driving.
Old May 22, 2007 | 03:46 PM
DJames's Avatar
DJames
Originally Posted by Z1 Performance
1. get good tires
I plan to track the car 1-10 a year, but the min would probably be 5 times a year. As in budget wise, best bang for your bucks. I've been reading a lot about the Stance Coilovers, seems like everyone loves them.
Old May 22, 2007 | 03:48 PM
Z1 Performance
Former Sponsor
not a fan personally of any "true" rear coilover, but everyone has their own opinions on this
there are some pretty comprehensive threads out there with reviews of just about every coilover out there - takes awhile to search, but you'll get a ton of good info
Old May 22, 2007 | 03:54 PM
jimmyloose's Avatar
jimmyloose
T2 Springs! Konis valved to match!
It'll pwn any of those cheapo coilovers.
Old May 22, 2007 | 03:56 PM
Tubbs's Avatar
Tubbs
love my zeal functions!
Old May 22, 2007 | 04:06 PM
DJames's Avatar
DJames
I guess i need to rethink my options then, cause i thought i was set on the Stance Coilovers.
Old May 22, 2007 | 04:12 PM
vince1611's Avatar
vince1611
Old May 22, 2007 | 04:17 PM
DJames's Avatar
DJames
Very Interesting,
Has anyone tested out the RS*R Coilovers?
Old May 22, 2007 | 04:22 PM
QuicksilverZ33's Avatar
QuicksilverZ33
What could be wrong with a true coilover setup? Is it that the weight is too much on one part instead of the two mounting places from the factory?
Old May 22, 2007 | 05:00 PM
Beau's Avatar
Beau
Originally Posted by vince1611
+1 Despite the forum's overwhelming support, I would never consider buying "true" rear coilovers for a number of reasons.
I also wouldn't recommend JIC either for anything close to a daily driver.
Could you elaborate on both of those thoughts? I want to understand why.
Old May 22, 2007 | 05:07 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
I would suggest doing some research. There are tons of coilovers for the Z33, it really depends on what you are expecting your car to do and what you want out of a coilover. You can start you research here.
Old May 22, 2007 | 05:17 PM
THE TECH's Avatar
THE TECH
Did the KW v3 come with the external reservoirs Andy?
Old May 22, 2007 | 09:10 PM
Gsedan35's Avatar
Gsedan35
Well liked by all that own them and have provided imput. In spite of offering Independent Double Adjustable rebound and compression dampnings, they leave never made onto my "consideration" list because of lacking full height adjustalilty to adjust ride height independent of spring preload and the setup uses progressive rear springs with a wide rate spread. Though since the rear springs don't bind coils to change rate, at least one cannot experience sudden rate changes during or close to at the limit handling.
KW coilovers Variant's 1,2&3
twintube construction,
V1=non adjustable dampning,
V2=adjustable rebound damping,
V3=separate adjustability for compression damping AND rebound damping .
Spring rates Front 485lbs to 525Lbs Rear: 240Lbs to 548Lbs (progressive springs)
Notes: High progressive rear spring rate spread that cannot be easily fixed because of the mounting diameters of the upper and lower spring seats in the height adjusting system. It still can be fixed, but would require a lot of phone calls and research that most won’t bother with, IMO it’s worth the bother.
Old May 22, 2007 | 09:15 PM
Gsedan35's Avatar
Gsedan35
I know the rears do. But I cannot find a good shot of the front units to know for sure.
Old May 23, 2007 | 07:06 AM
Z1 Performance
Former Sponsor
quite a lot, starting with geometry. It's different yes....different does not always mean better
I've been in 1 car that had them. The 'advantage' these have is you can slam the car on the ground, if you so desire. The downside was that when compared to other street friendly coilovers, they were not particularly well valved for rougher roads...but, it's all subjective I suppose
V3's have resevoirs front and rear:
Old May 23, 2007 | 09:54 AM
QuicksilverZ33
Thanks for the info...So basically true rear coilover setup is ideal for the track but not for rough roads?
