Got my StopTech Big brake Kit On!
350Z 2+2
on
I will definitely be at the NASA sponsored rack day at PMI July 21-22, and maybe some others, but if we have a get together before then, and you're around, you're more than welcome to check them out.
Will
350Z 2+2
on
I don't know, it is such a PITA to change the pads at the track. Any track pads that would be safe driving 60 or so miles on the highway, but still work good at the track?
Vendor - Former Vendor
-Erik-
on
Originally Posted by StopTech
With your setup, something like Hawk DTC70 up front and BHP XPS out back would take excellent care of you and still be very driveable to and from the track. The BHP pads are a dual use compound that can be left in all the time meaning you only have to change front pads before track days.
-Erik-
-Erik-
Originally Posted by DMK
Where are BHP pads made? Where can you buy them? Are they only made for stoptech?
FYI, the XPS compound is being discontinued from tha manufacturer so we may not be able to replenish our stock after we run out.
#40
350Z 2+2
on
Hey, I only went off the track once!
On another note, I now have a good bit of brake squeal when I come to a stop. I removed the pads and put that disc brake lubricant/anti-noise grease on the back of the pads, which slightly reduced the noise, but it is still quite noticeable. Anyone have any suggestions for other ways to reduce and/or eliminate the squeal?
Dave
Dave
