Got my StopTech Big brake Kit On!
Old Jun 1, 2007 | 04:57 AM
  #41
zzz350's Avatar
zzz350
Originally Posted by Dave 90TT
Hey, I only went off the track once!
On another note, I now have a good bit of brake squeal when I come to a stop. I removed the pads and put that disc brake lubricant/anti-noise grease on the back of the pads, which slightly reduced the noise, but it is still quite noticeable. Anyone have any suggestions for other ways to reduce and/or eliminate the squeal?
Dave
Bed your brakes, do a search for "Bedding Brake Pads". However if you are running slotted and cross-drilled rotors, you are fuct.
Old Jun 1, 2007 | 05:03 AM
  #42
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Bedded them as per procedures (10 stops from 60-10) let them cool off, did it again.
They are slotted, not cross-drilled, though.
Old Jun 1, 2007 | 05:46 AM
  #43
zzz350's Avatar
zzz350
Slotted are just going to be a bit noisy, drilled would make them even noisier. Turn up your stereo and the noise will go away.
Old Jun 1, 2007 | 07:05 AM
  #44
StopTech's Avatar
StopTech
Vendor - Former Vendor
The slot/drill pattern wont have an effect on the squealing noise. The Axxis Ultimate pads included in the kit do have a tendendcy to squeal at light pedal pressures at lower speeds which you are likely experiencing. You may want to try another bed in cycle to really build up the pad transfer layer on the rotors which is the best way to keep the squealing to a minimum.
Old Jun 1, 2007 | 07:15 AM
  #45
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Are there pads which have close to the same level of performance as the Axxis Ultimates, but are quieter?
Old Jun 1, 2007 | 07:48 AM
  #46
dklau33's Avatar
dklau33
There's the Axxis Deluxe pads which will be quieter and produce a lot less dust but the performance will suffer a bit compared to the Ultimates. Unfortuantely, I dont' think there's such a pad that has high bite, no dust, and no noise. There's always tradeoffs.
Old Jun 1, 2007 | 09:06 AM
  #47
zzz350's Avatar
zzz350
Spoken like a true retailer
Old Jun 1, 2007 | 11:20 AM
  #48
StopTech's Avatar
StopTech
We are the manufacturer, not the retailer.
As to the question of quieter pads with similar performance, that is a lot to ask since the Axxis pads are very tough to beat with regards to bite and temperature range on something that is very streetable.
A lot of guys like HPS pads pads (a lot of them dont like them either) which have less dust and noise but also a reduction in bite. Our parent company Centric parts offers a few compounds which have performance levels similar to that of HPS which are usually available for much less. If you have a compound in mind that we do not carry, you can check out the following link on our FAQ page to see what part numbers would be needed to fit our calipers.
http://www.stoptech.com/tech_info/faqs.shtml#20
Old Jun 1, 2007 | 01:04 PM
  #49
bamyi's Avatar
bamyi
Having two or more bed in cycle, will this effect performance? If so, how?
Old Jun 1, 2007 | 02:49 PM
  #50
StopTech's Avatar
StopTech
Additional bed-in cycles will serve to build up the pad transfer layer which is imperative for optimal performance since the pads work on adherent friction as opposed to abraisive friction. If the pad transfer layer isnt robust enough, it will wear away quickly or not have enough material to work at its best. More info here:
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
Old Jun 3, 2007 | 06:54 AM
  #51
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Well, doing another bed in cycle (even though I did two complete bed ins immediately after the install), did indeed get rid of the squealing.
However, I am still going to go with the Axxis Deluxe for street driving, and switch out to PFC 01's for track days.
Dave
Old Jun 3, 2007 | 07:26 AM
  #52
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Ok, here is some full side pics, after I washed the G
Attached Thumbnails Got my StopTech Big brake Kit On!-driver-side-front-high.jpg   Got my StopTech Big brake Kit On!-driver-side-low-front.jpg   Got my StopTech Big brake Kit On!-right-side-low.jpg   Got my StopTech Big brake Kit On!-right-side.jpg   Got my StopTech Big brake Kit On!-right-front-close.jpg
Old Jun 3, 2007 | 08:03 AM
  #53
OH6 G35's Avatar
OH6 G35
Holy Crap...Dave, your car looks AWESOME !!
You say "No Drop" but did you do a Suspension Upgrade ?
Old Jun 3, 2007 | 08:11 AM
  #54
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Car looks awesome Dave!!! BTW: Ada told me.
Old Jun 3, 2007 | 08:57 AM
  #55
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Stillen sways, and SPL endlinks, along with a front strut tower bar.
  #56
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Originally Posted by Robert_K
BTW: Ada told me.
About Jen's car? Yeah, oops...... I guess that's waht insurance is for.
  #57
OH6 G35's Avatar
OH6 G35
Nice !!
Old Jun 3, 2007 | 09:04 AM
  #58
Robert_K's Avatar
Robert_K
Didn't Go Cheap
It happens to the best of us. Did we add the SPL endlinks at my house?
Old Jun 3, 2007 | 09:29 AM
  #59
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
No, that was someone elses car, but I had done them at my house a week or so before, and was able to help.
Old Jan 7, 2008 | 06:11 PM
  #60
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Dave,
I know this is an old thread but any rubbing issues with the caliper & wheels? Well vs what happened at Hastings. I'm starting to worry this kit will not fit with my wheel size/offsets. Thanks!
