What's causing my front suspension clunk?
Old May 28, 2007 | 12:00 AM
SponGer's Avatar
SponGer
Default What's causing my front suspension clunk?
Hey there,
Drove to Anaheim yesterday and noticed that my front suspension clunked whenever I hit a bump on the road. Tried doing a search and found other threads about bad end links. How can I tell if they're bad? Could it be something else?
Old May 28, 2007 | 07:22 AM
Zridder19's Avatar
Zridder19
Could be a broken steering rack. I know my car did that and had to replace it. Yet the car still does it...hmm
Old May 28, 2007 | 10:39 AM
rkd350z's Avatar
rkd350z
maybe some bolt are loose. I had same problem after my coilover install and few days later I found out that I didn't titen the sway bar nuts. It was about to fall too.. soo close..
just go lift your car and check, it won't take you more than 1hr so do it.
Old May 28, 2007 | 11:01 AM
Checkmate58's Avatar
Checkmate58
Have you guys ever wondered that it could be the control arm hitting the inside fender well?
--Sam
Old May 28, 2007 | 08:37 PM
SponGer's Avatar
SponGer
Didn't have a chance to check it today. I have a feeling it's the sways and/or end links. Regardless, I'm going to recheck the entire front to make sure it's all torqued to spec.
Old May 31, 2007 | 06:11 PM
SponGer's Avatar
SponGer
My driver side end link nut was really loose. I torqued both sides back to spec and checked the rest of the suspension. I guess I'll have to re-torque those down each time I do an oil change. Oh yeah, I used a little Loc-Tite on each nut.
Obadabot
Jun 18, 2023 11:31 PM
_bit
Oct 2, 2015 07:49 AM
