How low can I go? with 19's
Got good advice on the OEM brembos so I thought Id ask another question.
Im planning on buying springs in the next month or so, and wasnt sure what springs i should go with. Im not completely sure I want to lower if Im going to need to roll or cut the fender. As of now the car has no clearance issues, but would definelty look Sweeeet dropped a little.
Currently running Volk GT-S/ F 19x9.5. R 19x10.5 17,18 offset
Thanks in advance
Thanks in advance
he must be running 275/35 if he hasn't had to roll or cut the fenders.
If you drop you car especially with that offset you either run mad camber when you drop or you roll/cut the fenders. My recommendation would be to roll the fenders so you don't have to put an extreme camber in the rear. If you have serious negative camber your going to wear out your tires easier (uneven wear).
I have that EXACT wheel setup..... I am lowered on tein S-techs and run 275 and 245. Under normal driving I did not rub at all, but if I drove hard into turns it would rub.... so I just rolled the fenders
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
