My zs FCKED
Old Jun 9, 2007 | 04:25 PM
ZSpectrum's Avatar
ZSpectrum
Default My zs FCKED
Ok so heres the situation, either my abs system has air bubbles in it(multiple bleedings) the calipers I just bought are fcked(highly doubt it) Or im retarted
My options are rebuilt all calipers and live with it. Rebuild just the rears and go stoptech 13 inch bbk up front or say fck it sell the z and buy a c5 z06. What to do?
Old Jun 9, 2007 | 04:43 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
What calipers were you installing?
Old Jun 9, 2007 | 04:47 PM
ZSpectrum's Avatar
ZSpectrum
Old Jun 9, 2007 | 04:49 PM
cleanandquick06's Avatar
cleanandquick06
c5 z06 imo
Old Jun 9, 2007 | 04:50 PM
JDMFairladyZ33
Originally Posted by ZSpectrum
06
Are you putting them on yourself or is Travis helping you?
ZSpectrum's Avatar
ZSpectrum
Travis did them.
Old Jun 9, 2007 | 04:55 PM
JDMFairladyZ33
Travis did them.
How many times did he bleed them? What method is he using?
Old Jun 9, 2007 | 04:56 PM
ZSpectrum's Avatar
ZSpectrum
He bled them like 8 times. My zs at jotech right now. Im gonna go the bbk route if the calipers are ****ed.
Old Jun 9, 2007 | 04:57 PM
JDMFairladyZ33
Damn if you get a set of BBKs then I'm going to have to step up too.
Old Jun 9, 2007 | 05:21 PM
350Z84's Avatar
350Z84
What color are yall's Z's, I've probably seen yall running around.
Old Jun 9, 2007 | 05:52 PM
WalkerT's Avatar
WalkerT
Professional
We bleed it as the z manual says the first couple times then we bleed it with the car on. That has been know to help move more fluid. The car might need to be presure bleed to make sure the air is out of the abs manifold. I have been having problems with my back (disk) and today after 7 hrs of work my back was calling it a day. I offered z spectrum to leave the car over night and have robert and I do a longer bleed in the morning but the tow truck was already on its way. I have done this install before and not had any problems. I swapped out his brake line with SS and did the same bleed a month ago a it worked like a champ. Worst case the right caliper is bypassing and needs to be rebuilt. Best case it needs a long 3hrs of bleeding to make sure the abs has no air in it. You can bench bleed it or presure bleed it. Or just bleed a full bottle of brake fluid through it.
I would not go BBK until you know the calipers are bad. The difference will be marginal at best.
Old Jun 9, 2007 | 07:08 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I am not familiar with the 06 calipers but when I did my Brembo upgrade I was having a heck of a time getting the fronts bled. What worked for me when I installed my brembos was to remove the top caliper bolt and loosen the bottom and rotate them so the nipple pointed straight up (while still keeping the pads on the rotors so the pistons don't fall in). After two more rounds of bleeding, I had a pedal that was hard as a rock.
Stoptech recommends this method if you are having problems because of the odd angle of the Z front calipers.
Chris
Old Jun 10, 2007 | 05:20 AM
zzz350's Avatar
zzz350
Just thought you should know that "retarted" is actually spelled "retarded", which makes your post all the funnier. No comment on the "rebuilt" vs. "rebuild" either (which makes this posts all the funnier).
Old Jun 10, 2007 | 05:24 AM
Z04's Avatar
Z04
this is coming from the guy who spelled California with a K
Old Jun 10, 2007 | 10:52 AM
ZSpectrum's Avatar
ZSpectrum
Dude fck off. I dont have any interest in your grammar or spelling lessons. Stay the fck out of my thread.
Old Jun 10, 2007 | 11:34 AM
ZSpectrum's Avatar
ZSpectrum
Someone delete this thread.
Old Jun 10, 2007 | 11:44 AM
dedmoonstears's Avatar
dedmoonstears
in such a situation dont you just wish that your retarded
Old Jun 10, 2007 | 11:48 AM
ZSpectrum's Avatar
ZSpectrum
I wish I had a gun that I could point at your head pull the trigger laugh and walk away.
Old Jun 10, 2007 | 12:31 PM
Eazzy's Avatar
Eazzy
Impatience and irrational action screw up many simple jobs. Personally, I would never buy a used Caliper (if thats the case) and not immediatly rebuild it just Cuz....start fresh and secure. Its hard to isolate the calipers with the SS lines because you dont want to collapse them. On the rubber lines you can gently clamp them.
I gravity bleed most everything, one cal at a time and tap the cal,lines and all components to shake loose air thats clinging.
Dumb, but are the banjos tight and the washers in place. ALWAYS keep in mind that you may be SUCKING air somewhere.
Obviously SOMETHING is wrong, but there are just not that many things that can go wrong in a brake system....Not like looking for a needle in a haystake so to speak.
If your fluid was filthy, you may have disrupted the master cyl and be bypassing. If you apply pressure to the pedal, does it slowly go to the floor??
Put away your Gun and start at A and work towards Z
Old Jun 10, 2007 | 12:58 PM
ZSpectrum's Avatar
ZSpectrum
Ive pretty much got it down to having air in the master cylinder/ abs system. My bluid is brand new ate super blue. My z will be force bled tomorrow and I will get back to you. My friends car acts the same way mine does and that was his solution. We will see. Also I have stainless steel lines.
