What set of springs should I get?
Ive been looking into purchasing a set of springs for my Z for quite a long time now and still can not make a decision. Could you please help me decide between Eibach Pro v. Tanabe GF210. I know Eibachs are progressive springs and Tanabes are linear. Let me get some feedback from you guys, positives and negatives going with either ones. I also know that Eibachs lower the car 1F/1R and Tanabes 1F/1.2R. Are you using any Camber and Toe Adjusters? Thanks
Originally Posted by soleil350z
i'm using the tanabe gf210 and no camber and no problems
If you lower your car more than .7 of an inch, your tires and shocks are going to be PISSED.
Originally Posted by Fluid1
Jesus....don't listen to this kind of person. No intelligence in modding.
Tanabe GF210 Series 350Z progressive springs 1/1.2 drop on 350Z G35 drops will be higher
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Eibach 350Z progressive springs 1/1 drop* on 350Z G35 drops will be higher
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
im slammed on stance coilovers. -3 degrees up front and -4 out back. i have the cusco camber arm for the front and the camber arms for the back been lazy putting it on. but ive had them this way for 22k miles, surprisingly my camber wear isnt as bad as i thought it would be. prolly bcus im slightly toe in. anyways im rambling. i think you should get coilovers. and slam it. who cares about tires. hahahahahaha.
http://www.xanga.com/jchewy
Originally Posted by Z1 Performance
tanabes are not straight linear - they are mildly progressive, just less so than Eibach
either is a good choice
Actually Adam it's the other way around. The GF210's have one additional progressive coil loop and will have a greater rate spread between the them and the Pro-kits. Even with 2 progressive coil's the Pro-kit's still have rate spread, though less then Sportlines.
Tanabe 350Z GF210
Eibach 350Z Pro-Kit
Originally Posted by XuperXero
That's a 1.7" drop? Even my car with Nismo T2 Spring with 1" drop is more slammed that that...
That picture was taken the same day that I installed the springs/struts, so now, a year later, they have settled in. I'll get a new PIC this week.
Originally Posted by SuperBlack350
i have an 03. are the tanabe gf210 or nf210 actually smoother and softer ride than what i have stock?
Your oem 2003 are linear
Spring rates in LBS 314/342
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” higher
Spring rates in LBS 314/353
The NF210's are pretty much the same as oem, catch is you've given up 1.2" of suspension travel, yet you've done so with pretty much zero increase in spring stiffness vs oem. So where is the added protection to keep you off the bump stops which are very unforgiving in the front and cannot be trimmed.
In case it helps here's a full list of 350Z lowering springs with specs.
Oem baseline
2003-2004 (unrevised suspension)
314/342 linear
2004.5-2007 (revised suspension) includes all roadster production
314/427 linear
Eibach 350Z Pro-Kit progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 rear 316/421
Eibach 350Z Sportline progressive springs 1.2"/1.2"
Spring rates in LBS initial/final front 239/400 rear 257/435
Notice extreamly high rate spread between initial and final rates
RSR 350Z linear springs .6”/.6”
Spring rates in LBS 345/417
Hotchkis 350Z Linear springs .6”/.8”
Spring rates in lbs 340/330
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402
Tein H-tech 350z linear springs .3”/.2”
Spring rates in LBS 358/375
Progress Technology progressive springs 1.0”/1.0”
Spring rates in LBS 425/385 (final rates only, softer intial front progressive rate unknown)
Swift 350Z linear springs .8”/.6”
Spring rates in LBS 336/364
Nismo T2 350Z Linear springs 1”/1”
Spring rates in LBS 625/700
Do NOT run them with OEM shocks of any kind
Vogtland 350z progressive springs 1”/1”
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
Kg/mm springs 350Z
DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Kg/mm DRacing progressive springs 1.2”/1.2”
Spring rates in LBS initial/final front 252/454 initial/final rear 252/482 rear
Whiteline 350Z linear springs (control)
Front: Part # 73219,
Spring rate 365 LBS Drop: .8"-1"
Rear: Part # 73220
Spring rate 445LBS Drop: 1"-1.2"
(sold as 2 front springs and 2 rear springs)
www.whiteline.com.au/store/
Espelir 350Z progressive springs Drop .4"/.4"
Spring rates in LBS 386/515 (softer initial rates are unknown)
H&R sport 350Z progressive springs Drop 1.3"/1"
370/400 (softer initial rates are unknown may be simular to Sportline spread)
Tokico D-spec shock & spring package
350Z - DSK512 - 375f/375r - Linear Springs 1"/1.5"
Nismo S-tune shock & spring package (twin tube construction, uses progressive springs)
350Z .8"/.8" drop
Spring rates 448/504
Tanabe 350Z GF210
Eibach 350Z Pro-Kit
Tanabe 350Z GF210
Eibach 350Z Pro-Kit
In all sincerity, your barking up the wrong tree. Your oem 03 shocks are doing way more to the car's ride quality then the springs are. You can bandaid things with progressive springs and get the drop you want to see. But to really deliver on what your after a more forgiving shock or one that can be adjusted to be more forgiving is in order. Better shocks will allow you to run what is actually a stiffer spring yet have improved ride and drive quality, yet hopefully stay off the bump stops in spite of being lowered.
Tanabe NF210 Series 350Z progressive springs 1.2/1.2 higher
Oem baseline
314/342 linear
314/427 linear
Eibach 350Z Pro-Kit progressive springs 1/1
RSR 350Z linear springs .6/.6
Hotchkis 350Z Linear springs .6/.8
Tein S-tech 350Z springs .7.6 (fronts are slightly progressive, rears are linear)
Tein H-tech 350z linear springs .3/.2
Progress Technology progressive springs 1.0/1.0
Swift 350Z linear springs .8/.6
Nismo T2 350Z Linear springs 1/1
Vogtland 350z progressive springs 1/1
Kg/mm springs 350Z
Kg/mm DRacing progressive springs 1.2/1.2
Rear: Part # 73220
350Z .8"/.8" drop
Oem baseline
314/342 linear
314/427 linear
Kg/mm springs 350Z
Rear: Part # 73220
350Z .8"/.8" drop
