What set of springs should I get?
Originally Posted by twotonez
Originally Posted by hkman78
what is the difference between "progressive" and "linear" springs? Which one is better?
Progressive - Spring rate changes as you put load on it. For example, when you corner, the more you push on the side of the car during the corner, the harder the springs get. Initial spring rate is without load on the springs and final spring rate is the max spring rate when under load.
Linear - Kind of self explanatory. Spring rate stays the same under all condition.
Applications: Progressive is good for street as it can absorb bumps and whatnot. Linear is firmer and better designed for track/auto-x.
Originally Posted by JCZ33
SPRINT
hands down one of my favorite spring manufacturers. Smooth ride and great handling all on a super slam drop. Had these springs on several cars. Put my Neuspeeds to shame.
I have these now:
Espelir 350Z progressive springs Drop .4"/.4"
Spring rates in LBS 386/515 (softer initial rates are unknown)
But I have yet to put them on. Waiting for my motor build and TT to be done.
I have these now:
I have these now:
SPRINT Springs
Tokico d-specs - full stiff front / 3/4 stiff rear
Hotchkis sways(the ones with four holes on the front) - hole three front, hole 2 on the back.
And I live in the CITY
Smoothest tighest handling car i've drive yet!
Tanabe GF210 have got to be the most popular springs for the Z that Ive seen so far. I actually might swap the Tein S.tech for those once I get my camber/toe kit installed and alignment done in the fall.
the bigger diameter spring is for the front or the rear?
also, I just bought some tanabe GF210. It comes with a groove attached right in the middle of the each spring. Anyone knows what it is for?
Ok I'll keep it short and simple, refer to the post above to understand why.Original question is,....
Originally Posted by SuperBlack350
i have an 03. are the tanabe gf210 or nf210 actually smoother and softer ride than what i have stock?
Groove right in the middle of each spring? Can you take some pics that show what your talking about?
if you were to keep your stock shocks, which would give the more comfortable ride? sorry for the newb question, but if i drop it and i can feel every bump on the road, i would be pissed.
Originally Posted by Gsedan35
The bigger or wider diameter springs are the rears.
there's a piece of plastic that wraps around 2 layers of the spring and each spring has it. I ended up using the stock and leave them there.
So, should I go with Eibach Pro springs or GF210s? I've never taken and don't plan on taking the car to the track so I would guess Eibach's are the way to go? Correct?
I'll take it that drop height is more important then performance? For performance sake I'd take S-tech's over GF210's. You can purchase Tokico springs seperately btw.
I can't find a dealer or vendor that will sell the Tokico springs seperately.
some vendors might choose to sell the springs alone but tokico themselves do not offer it that way
