Tein S Tech Spring Pictures Needed
Old Jul 25, 2007 | 02:12 AM
Yousef89's Avatar
Yousef89
Default Tein S Tech Spring Pictures Needed
Hey everyone, I want to get springs to lower my Base '06 on the stock struts, and have decided on Tein S-Techs, because, from what I have read, they offer a good ride and a nice looking stance. I have read that they are softer than the stock springs, does anyone know if this is true or how they handle? I also really need to see pictures of the wheel well gap on cars that run the S-Techs before I buy them. I know that these pictures are out there but i have searched for hours and only found a few good ones. Any help or pictures would be appreciated.
Old Jul 25, 2007 | 04:55 AM
clipso 01's Avatar
clipso 01
+1 i just bought these
Old Jul 25, 2007 | 02:01 PM
Yousef89's Avatar
Yousef89
How do you like them? Any pics out there?
Old Jul 25, 2007 | 03:37 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
absolutely fantastic springs for stock struts...they look and work great
Old Jul 25, 2007 | 06:14 PM
redlude97's Avatar
redlude97
just compare the stock springrates against the s-techs. Also the front s-tech springs are progressive while stocks are linear. It also depends on what year Z you have as the springrates changed in 04.5
Old Jul 25, 2007 | 10:26 PM
Yousef89's Avatar
Yousef89
I have an 2006. Can you help me out with some pics?
Old Jul 25, 2007 | 10:34 PM
black06z's Avatar
black06z
Old Jul 25, 2007 | 10:39 PM
black06z's Avatar
black06z
Old Jul 26, 2007 | 06:54 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I think the s-tech puts the car to a proper stock hight, the fronts are stiffer by quite a bit and the backs are just a bit softer (within 15lbs if i remember correctly).
My before
after
Old Jul 26, 2007 | 10:22 PM
Yousef89's Avatar
Yousef89
Thank you guys, the pictures and comments really helped. I have decided that I will get the S.Techs and H&R spacers.
Old Jul 28, 2007 | 01:03 PM
Z1 Performance
Former Sponsor
S Tech's in stock...and since we're in NY, you get em in a day
Spacers, we can get the H&R (pricey though) or Ichiba
Old Aug 6, 2007 | 11:22 AM
vtb11's Avatar
vtb11
how are htechs compared to stechs on a g35 anyone?
i was looking into these too, great looking pictures
also, do both htech and stech need camber kits?
Old Aug 6, 2007 | 11:25 AM
Nexx's Avatar
Nexx
foward rake ftl. hotckis is a better spring imho.
Old Sep 13, 2007 | 11:29 AM
ginobetterfly's Avatar
ginobetterfly
Quick questions:
1. With Tein S springs, i will not need to get a camber kit, right?
2. The drop is slightly higher than nismo s-tune susp? about .5" - .7" in rear?
Thanks for help.. i think this is right but want to be 100% sure.. I think this will be next mod...
EDIT: Some people are saying that they love the S tech, some are saying the a$$ barelly dropped if at all, some are saying its a little higher... what the deal??? Should i go with the hotchicks (umm sp?) or maybe eibach pro kit? i dont want the drop lower than .8"... dont want to get camber kits.. i have an 05, so that should be a factor too..
Old Sep 13, 2007 | 12:10 PM
redlude97's Avatar
redlude97
you can do a springmount mod to the rear to even out the drop
Old Sep 13, 2007 | 09:04 PM
Gsedan35's Avatar
Gsedan35
You won't need it with the H-techs, you you will with the S-techs
Tein H-tech G35 coupe .6“/.3“(fronts are progressive, rears are linear)
Spring rates in lbs 324/260 (final rates only, softer intial front progressive rate unknown)
Tein S-tech G35 coupe 1.2”/.9” (fronts are progressive, rears are linear)
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
Just to mention it your 04 oem G35 coupe spring rates are 314/342
So you can see how the G35 and 350Z Tein springs differ.
Tein H-tech 350z linear springs
350Z drop .3"/.2"
G35 coupe drop .8”/.6”
Spring rates in LBS 358/375
Tein S-tech 350Z springs (fronts are slightly progressive, rears are linear)
350Z drop .7"/.6"
G35 coupe drop 1.2"/1,1" (non recommended for use with oem shocks unless car was delivered with 19" wheels)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
A_MEISTER
Suspension
Oct 25, 2015 04:50 PM
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
