Will cusco sway bar fit with a 5/16 plenum spacer
Old Aug 29, 2007 | 10:37 AM
chamois's Avatar
chamois
Default Will cusco sway bar fit with a 5/16 plenum spacer
title says it all just wondering if it will have enough of a gap between the plenum and the strut bar?
Old Aug 29, 2007 | 11:09 AM
GReddySetGO's Avatar
GReddySetGO
Your title says sway bar
Old Aug 29, 2007 | 11:27 AM
DustinZ33's Avatar
DustinZ33
I don't think you're going to get a cusco sway bar to bolt up where the strut bar is.
Old Aug 29, 2007 | 12:00 PM
Ruthless18x's Avatar
Ruthless18x
Yes it will. You might have to shim the bolts a little like the JIC but it will fit fine.
Old Aug 29, 2007 | 12:12 PM
Motormouth's Avatar
Motormouth
is this an australian engine? upside down?
j/k. but yeah, do you have the spacers for the stock bar? you should be able to reuse them.
Old Aug 29, 2007 | 12:49 PM
chamois's Avatar
chamois
i meant strut bar. i have spacers thanks
Old Aug 29, 2007 | 12:53 PM
gsazabi's Avatar
gsazabi
I used to have problem with the stock strut bar rubbing against my 5/16 plenum spacer even with spacers and washers installed.
Bought Cusco and solved the problem. Noticable more clearance than the OEM strut.
Oh btw Cusco sway bars will DEFINITELY clear the plenum spacer LOL
Old Aug 29, 2007 | 03:20 PM
Vertex350's Avatar
Vertex350
+1 I have the cusco strut bar with the 5/16 spacer, you should be fine.
Old Aug 29, 2007 | 03:27 PM
bleunetizen's Avatar
bleunetizen
anyone using AAM angled spacer ?
Old Aug 29, 2007 | 03:37 PM
Ninja350Z's Avatar
Ninja350Z
Living in 350Z
Default yep
Yeah I have the AAM spacer. GT Spec strut bar fits over it fine.
Old Aug 29, 2007 | 05:37 PM
chamois's Avatar
chamois
yes AAM is what i have i like it.
Old Aug 30, 2007 | 07:02 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Yes th Cusco fits the 1/4 inch, 5/16, and AAM spacers...alot more to the OEM hood too
(and in stock
hulkout
Apr 28, 2017 09:00 PM
350z82
Oct 1, 2015 06:25 PM
