SPC front a-arms hitting top frame
Old Sep 16, 2007 | 10:04 AM
darklocust's Avatar
darklocust
Default SPC front a-arms hitting top frame
Go: https://my350z.com/forum/brakes-and-suspension/302063-tokico-dsp-9-owners-do-you-have-bump-stops-installed.html
Old Sep 16, 2007 | 01:09 PM
redlude97's Avatar
redlude97
do you know if they are the latest revision of the SPC arms? The old ones knocked, but they revised them so they would not less
Old Sep 16, 2007 | 04:52 PM
chimchim's Avatar
chimchim
It looks like you have the original version of the arms. The revised version have an upward bend in them so the shock/spring have an extra inch or two to compress. They also come with some poly washers that you can put on your struts to add to the height of the bumpstops on the struts.
I returned my original arms and they replaced them with the revised units.
Just tell them that you want the revised arms made for the g35 coupe.
Supposedly, the sedans don't have this problem.
The only time I knock is when I have my Teins set at the softer settings and hit a dip at high speed. At the stiffer settings I don't knock at all.
good luck
Old Sep 16, 2007 | 05:09 PM
darklocust's Avatar
darklocust
Go: https://my350z.com/forum/showthread.php?t=302063
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
