Anyone get away with using camber bolts?
Old Sep 30, 2007 | 01:41 PM
cubu's Avatar
cubu
Default Anyone get away with using camber bolts?
was wondering if i even need the arms, according to SPC the bolts alone can adjust 3 +/- . thanks for any info
Old Sep 30, 2007 | 02:29 PM
cubu's Avatar
cubu
... now that i look at the Tein Comfort Sport specs, it looks like i won't need rear camber/ toe cause the rears only go +.055 to -.63 with recommended height of -.39. am i understanding this right? recommended front drop is -.47, so if i stick with recommended height i shouldn't need camber adjustments? thanks for any help
Old Sep 30, 2007 | 09:08 PM
Gsedan35's Avatar
Gsedan35
As you have correctly discovered, Tein's recommended ride height setting for the CST coilover on the 350Z is -.4"/-.5" If you follow thier recommendation and use that ride height, you will not need aftermarket alignment parts.
http://www.tein.com/nissan.html
Old Oct 1, 2007 | 04:37 AM
john1982's Avatar
john1982
i was wondering the same thing.....could i just use camber bolts to get back in spec.?
Rowlett
Misc.
Oct 2, 2015 10:38 AM
