Bigger pedals for heel and toe ?!
Old Jul 10, 2003 | 10:41 PM
importriders's Avatar
importriders
Originally posted by D_Nyholm
Wow, maybe it is just me, but I feel that the stock pedals are almost perfectly placed for the "rocking" heel-toe method. Maybe I have really wide feet (size 11), I really dont' think that is the case though.
Nope...had many NASA instructors drive my car and they ALL said heel-toe sucks in the Z.
Old Jul 11, 2003 | 10:33 AM
Buub's Avatar
Buub
I'm not very good at heel-toe but the pedals in the Z just do not inspire confidence. Sure I might be able to hit both with the edges of my shoe, but that does not inspire confidence, especially for a novice. I'd really hate to have the edge of my shoe slip off one or both peddles in the middle of a high-speed apex; that wouldn't be pretty.
The pedals definitely need to be bigger, or at least wider.
Old Jul 12, 2003 | 07:33 PM
raceboy's Avatar
raceboy
How about doing it the easy and free way. Just remove the entire throttle pedal assembly and then bend it so the throttle pedal is 1/2-3/4" closer to the brake? I tried to do it in the car without removal, but it's impossible.
Old Jul 13, 2003 | 05:50 AM
MannishBoy's Avatar
MannishBoy
I think Doug tried that, and it gave him some throttle problems with the throttle position sensor. It will now sometimes get out of range, and throw some codes and force the car into limp mode. Be careful if you try it.
Old Jul 13, 2003 | 08:41 PM
raceboy's Avatar
raceboy
You just have to be careful to only bend it at the bottom. Otherwise, it will go past the stop and you will throw a code.
Old Jul 13, 2003 | 10:30 PM
nwind21's Avatar
nwind21
Man that's some work and possible ruining the pedal assembly. I would just spend the 30-40 bucks for a new pedal set + 20-30 min to install and VIOLA... you can now do heel and toe w/o worrying that you screwed up something.
Old Jul 13, 2003 | 10:36 PM
raceboy's Avatar
raceboy
Bending some metal is "some work?" Took 10 minutes, no problems.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
