coilover comparisons?
Old May 29, 2003 | 01:11 PM
toykilla's Avatar
toykilla
Default coilover comparisons?
Now that there is a variety of coilover systems to choose from, does anyone know enough about these to give some type of comparison?
Alot of people like nismo, but no height adjustability??
Currently available:
Nismo
HKS
Veilside
Cusco
TEIN
JIC
I want something that isnt rediculously stiff, but will perform better than stock and have height adjustability.
Suggestions?
Old May 29, 2003 | 01:27 PM
jran76's Avatar
jran76
The Nismo is not a coilover, just spring and shock.... If you do a search you will find the spring rates for all you listed with the exception of the Veilside. I believe all the coilovers also include the upper pillow ball mount (for the front).
The JIC (FLT-A2 I believe, and more of a track setup) is the stiffest, Tein is close, the HKS (LS) is the softest, the HKS Hyper II's are pretty close to the Tein's as far as spring rating.
If you want something that is adjustable and not too stiff try the HKS LS's or the Tein w/EDFC....
Old May 29, 2003 | 01:35 PM
BZNYA's Avatar
BZNYA
Anybody have more in depth info on the Cusco Zero 2 and Zero 2-R in English????
Old May 29, 2003 | 02:11 PM
jran76's Avatar
jran76
https://my350z.com/forum/showthread....o+and+coilover
Here is some more Cusco info... basically one is adjustable, the others not.
Old May 29, 2003 | 06:10 PM
Gsedan35's Avatar
Gsedan35
Spring rates are listed eh. All I see are metric KG numbers. I'd love to see a unified listing for the top 5 coilovers and what the stock spring rates are, would especially love if said list was in LBS.
In any event, what is the conversion formula to convert KG to LBS. I tried a site that offered a conversion system, but the results made NO sense what so ever.
Does anyone have stock spring rate info?
Old May 29, 2003 | 06:21 PM
failsafe's Avatar
failsafe
....for your health
1 KG = 2.205 Inches
Old May 29, 2003 | 11:39 PM
Gsedan35's Avatar
Gsedan35
Originally posted by failsaf3
1 KG = 2.205 Inches
Ok, that's a start, thanks. But with say, the Teins your running. They are 10kgf/mm front and rear. What is the formula to figure out how many lbs their spring rates are. Ok ok, I realize that Tein is a bad example to bring up cause their web site does tell you in lbs, next to the metric figure.
But I need to know how to do the formula for all the other makers. Once I know, I'll develope a data base for every single spring and coilover system I can get info on (H&R will NOT reveal spring rates so can't do them) and do a post showing spring rates in lbs. I have a set of 350Z springs and if no one know's the stock spring rates, I gotta send them off one of these days to be tested to find out the stock spring rate.
Old May 30, 2003 | 04:22 AM
turbo03's Avatar
turbo03
As soon as I get my Zero 2 I will post a review. They left Japan last month on a container shipment.
thanks,
Greg
Old May 30, 2003 | 12:36 PM
D`Funkaladu`'s Avatar
D`Funkaladu`
Default here it is
To convert Kg/mm to lbs/inch multiply by 11.52.
Ex. 10Kg/mm x 11.52 = 115.2lbs/in.
Here's the conversion if you are interested
1 kg/mm x 25.4 mm/1 inch x 1 lb/2.205 kg = 11.51927 lb/in
Old Jun 4, 2003 | 03:43 PM
1200tt's Avatar
1200tt
veilside suspension is made by Kei Office, so i'm sure it's pretty good too.
Old Jan 21, 2004 | 01:17 AM
mchapman's Avatar
mchapman
Just multiply by 56.
10k X 56 = 560lbs
Stock 347lbs front 419lbs rear
Cusco z1/z2
(9k)504,(10k)560,(11k)616,(127)672 front & (7K)392lbs rear
NISMO 448lbs linear front and 504lbs rear progressive
Tein Basic 504lbs front and rear
Tein CS 392lbs front and rear
Tein Flex 671lbs front and rear
Jic FLA-2 350Z 560lbs front 672lbs rear
Jic FLA-2RS 350Z & G35 coupe 869lbs front 1008lbs rear
HKS hipermax LS 350Z 448lbs front and rear
HKS hipermax II 504lbs front and rear
Tanabe PRO S-0C rates unknown
VeilSide Standard Coilovers 350Z rates unknown
VeilSide Pro Sports Coilover 350Z rates unknown
I got some that list from another post.
Murray
Old Jan 21, 2004 | 05:00 AM
daytona350z's Avatar
daytona350z
got the HKS and love them...hypermax 2 version
height and dampening adj...
Old Jan 21, 2004 | 11:54 AM
mchapman's Avatar
mchapman
Are they a good stiff ness? As in not too stiff?
How much did you pay?
Murray
Old Jan 21, 2004 | 12:14 PM
daytona350z
Murray
very nice ride when you adjust em down, and can also be stiff...personally i run medium all around. with setting @ <12 feels better thn stock.
paid ~1500
Old Jan 21, 2004 | 12:33 PM
___DJK___'s Avatar
___DJK___
Ive got the HKS LS+ which have adjustable height and dampening. Im not sure what the spring rates are cuz everything is in japanese
Using the medium dampening setting (15 out of 30), I can tell you the overall ride is very similar to stock, but the handling is much better.
Old Jan 21, 2004 | 01:16 PM
protocav's Avatar
protocav
DJK...where did you pick up the LS+ coilovers?
i didn't think that they were out yet.
chad
Old Jan 21, 2004 | 03:44 PM
___DJK___'s Avatar
___DJK___
chad
I got mine through Sprewell Racing in San Gabriel, CA. Their phone number is 626 309-1771, ask for Frank.
You can check out some pics of them installed on my car in this thread:
https://my350z.com/forum/showthread....threadid=54224
Old Jan 21, 2004 | 03:50 PM
jimster716's Avatar
jimster716
I have the TEIN Flex with EDFC. I love this setup. The coilovers aren't as stiff as some others like the JIC but I have learned that too stiff isn't that great for traction on a faster surface autocross track. I learned this through driving practice and the instant adjustment by the EDFC made my life a helluva lot easier by easily being able to play with suspension settings...that rear strut bar would make manual adjustment a bear.
Old Jan 21, 2004 | 09:30 PM
Gsedan35's Avatar
Gsedan35
Whoa, the HKS LS dampeners cannot be adjusted, you must be talking about the hipermax II, big diff between the LS the the II's. The valving between the two systems is quite different, on the soft side or luxury biased for the LS. Of course the LS systems "springs" can be adjusted.
Old Jan 21, 2004 | 09:39 PM
Gsedan35's Avatar
Gsedan35
10k X 56 = 560lbs
Cusco z1/z2
Murray
Sidenote on the flex rates vs the Jics.
F/R spring rates
672*/672*
*original kits were 560/560, most product reviews are based
on the 560/560 rates, buyer beware if your using these
review's to make a purchase decision.
Front to rear spring rate balance change VS OEM
350Z/G35 Coupe +94% front +60% rear (34% transfer to front)
Now same comparison for the Jic's
balance VS OEM changes to:
350Z/G35Coupe +65% front +60% rear (transfers 5% to front)
Guess which setup I'd rather have, the one that moves less roll stiffness to the front, a lot less. Sway bars are to fine tune, not to overcome that kind of mismatch.
