Camber
Old May 30, 2003 | 12:32 PM
lotus's Avatar
lotus
Neg camber is not a bad thing you just dont want too much of it. I think the Z has a -1.3 deg stock camber in the rear. Ususally springs that only lower the car around 1" will still keep the car close to spec. Over time as the spring compresses a bit as most do you might have it add a little more neg camber. If you track your car alot you will increase grip in corners with neg camber. But for everyday driving it takes its toll on tires. If you run the same size tire all the way around its not a problem. You could simply rotate the tires to even the wear. But if you are running different size wheels front and rear you are stuck buying new tires more often.
The other thing to remember is as you straighten camber out you change the toe of the wheel. The stock suspension gives you really no way to adjust toe. Thats why after correcting a fair amount of neg camber its important to have toe rods to correct the toe of the wheel. If you look close at the pic from above photo you can see the toe is also different along with the camber.
Old May 30, 2003 | 02:13 PM
djkern's Avatar
djkern
here are the numbers from my printout....
front left ---> -0.6
front right ---> -1.3 (no idea why this is so much different from the other side??)
rear left ---> -1.8
rear right ---> -1.7
so, how are those numbers???
djk
Old Jun 23, 2003 | 09:21 AM
zwindsor's Avatar
zwindsor
Twisty addict
Default Control arms
dwnshift,
What's the latest on those rear arms....availability....pricing?
Tks
Old Jun 23, 2003 | 09:38 AM
djkern's Avatar
djkern
can anyone tell me how my number are? let me know if i should go back and check it again???
Old Jun 23, 2003 | 09:57 AM
failsafe's Avatar
failsafe
....for your health
djkern- try and get the front closer to each other (-1.3 each). You may also want to try and bring your rears a little closer as well. -1.8 isn't critical but will wear your tires as lotus mentioned.
front left ---> -0.6 (get this adjusted closer to the right)
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
