Camber kit help...
Old Nov 22, 2007 | 01:16 AM
Knightrider's Avatar
Knightrider
Default Camber kit help...
I lowered my Z 1 inch on Eibach springs. What kind of camber kit do I need. I've been doing some research and some kits say rear toe +/-3.0. What does that mean? Would that fix my alignment for the rear. What would I need to correct the alignment in this situation. I prefer Eibach camber kits.
Old Nov 22, 2007 | 05:45 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the kit you need:
http://www.z1auto.com/prodmore.asp?m...ng&prodid=1314
allows for rear camber and toe adjustments - and easily the most popular rear camber kit on the market for these cars. Alignment products is all SPC makes.
When you see rear toe +/- 3.0, they are talking about degrees of adjustment. The SPC kit will give you up to 4 degrees positive or negative camber adjustment, and 3 degrees positive or negative toe adjustment
Or if you prefer an Eibach Box you can get the exact same kit from them: http://www.z1auto.com/prodmore.asp?m...ng&prodid=2890
The Eibach kit is made for Eibach by SPC - same exact parts, different box, but the Eibach is a few dollars less
Both in stock
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
