View Poll Results: Which swaybar do you use if it makes clunking/popping/knocking noises
Hotchkis
51
37.23%
Cusco
4.38%
Stillen
13
9.49%
Eibach
0.73%
350evo
0%
No noise
66
48.18%
Voters: 137. You may not vote on this poll
Does your aftermarket swaybar make clunking/popping/knocking noises?
Old Feb 8, 2007 | 12:35 AM
Cloud's Avatar
Cloud
Default Does your aftermarket swaybar make clunking/popping/knocking noises?
If so which swaybar are you using?
Old Feb 8, 2007 | 12:37 AM
Cloud's Avatar
Cloud
Doing this to find out if hotchkis are the only swaybars that have the problem
Old Feb 8, 2007 | 05:49 AM
nkohler's Avatar
nkohler
cusco, no noise
Old Feb 8, 2007 | 06:35 AM
Fluid1's Avatar
Fluid1
Originally Posted by nkohler
cusco, no noise
+1
your poll doesn't make sense tho...people are going to vote for what they have on their car.
Old Feb 8, 2007 | 06:39 AM
IIQuickSilverII's Avatar
IIQuickSilverII
yeap its confusing.......
Old Feb 8, 2007 | 07:25 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I have Cusco on my '06 and I had Stillen on my '04. I never had any problems with my Stillen bars, which were installed by the dealership. But I had those noises start shortly after I had my Cusco bars installed by a local speed shop. So I had my dealership check it out during my next service interval. It turned out that the speed shop that installed the sway bars did not torque the bolts/nuts to spec, so they became loose.
My dealership tightened them back up to spec and I have had no noise or problems with my Cusco sways since... and that was about 10,000 miles ago.
Needless to say, I will not be going back to this speed shop ever again, since they can't even do something as simple as putting on a set of sway bars correctly.
Old Feb 8, 2007 | 07:46 AM
BamBam's Avatar
BamBam
I have hotchkis and no noises... But I have the ATS clutch and open dumps... Maybe I just don't hear it making noise.
Old Feb 22, 2007 | 09:54 AM
Sunset350ZR's Avatar
Sunset350ZR
What is spec tightness?
Old Feb 22, 2007 | 12:50 PM
MarkM's Avatar
MarkM
I bought Nismo as quite a few members in here had complained about Hotchkis noise. Nismo s are fine!
Old Feb 22, 2007 | 02:57 PM
DavesZ#3's Avatar
DavesZ#3
It also isn't a very valid poll because you're not finding out how many are out there. If there are 10,000 Hotchkis and 100 Cuscos in use, and 100 Hotchkis and 5 Cusco users report problems, which one is better? The Cusco because only 5 people had problems? Or the Hotchkis because of the lower percentage (1% vs 5%) of problems.
Old Feb 22, 2007 | 04:59 PM
VIZAGE's Avatar
VIZAGE
Hotchkis: No probs.
Old Feb 22, 2007 | 05:05 PM
ohSIXz's Avatar
ohSIXz
i dont have em on my Z. but i had suspension techniques sways on my 98 civic, and they made noise at times.... turns out i pinched the bushings off my endlinks. just had to get some new bushings... that would probably be yer problem since everyone else has replied with no sounds. and its probably on the front too... i never had a problem with the bushings on the rear.... wait yes i did. never mind ;x
Old Feb 22, 2007 | 05:08 PM
failsafe's Avatar
failsafe
....for your health
Cusco, no noises.
Old Feb 22, 2007 | 05:11 PM
Jay'Z's Avatar
Jay'Z
I have hotchkis and no, no noises........ I have so much clacking and popping from my Nismo Lsd and Clutch/ flywheel combo.. I prob wouldnt know anyways.. Lol.. It wouldnt bother me..
Old Feb 23, 2007 | 06:48 AM
Lawn Dart's Avatar
Lawn Dart
I had a clunking noise with Cusco stabilizers, however I had a major accident before I had a chance to see if it was the culprit or not. Since my front and rear subframe and lots of suspension pieces were replaced, I haven't had the problem anymore.
Old Feb 23, 2007 | 08:42 AM
UltraYellow350z's Avatar
UltraYellow350z
hotchkis no noise
Old Feb 23, 2007 | 08:43 AM
SpoilsofWar's Avatar
SpoilsofWar
Where is the button for the Progress bars?
Not that mine make any noise though
Old Feb 23, 2007 | 09:43 AM
abui01's Avatar
abui01
I've had both Hotchkis + Cuscos with no noise... grease those bushings!!!
Old Feb 23, 2007 | 04:59 PM
myG35zx's Avatar
myG35zx
I know I have said this several times already, but check the brackets that secure it to the frame. Even though they may look secure, I have found that they can be tweaked a bit that then causes "clunks" when driving.
Old Feb 24, 2007 | 06:59 PM
Tekwon-V's Avatar
Tekwon-V
hotchkis setup (medium front & rear) and clunking. mostly when i go down an incline at an angle; one wheel touching the flat pavement first.
