Quick fix for front end a-arm clunk?
Old Nov 24, 2007 | 06:45 PM
grudum's Avatar
grudum
Default Quick fix for front end a-arm clunk?
So when Im going slow, like idling or rolling out of the driveway, i have a clunk coming from the front suspension when i turn the wheel a certain way.
I know theres a TSB, and a DIY fix that have you take the front strut brace off and remove the shock to be able to get at the nut on the upper arm and give it a half turn or whatever to make it stop clunking...
but has anyone found a tool that you can fit in there without taking apart the front end or having to take it to the dealer?
Old Nov 24, 2007 | 06:48 PM
Axelerate's Avatar
Axelerate
Yeah a 14mm wrench.
I thought I had the clunk, but it was a bad sway bar endlink. I would check those first.
Old Nov 24, 2007 | 06:54 PM
grudum's Avatar
grudum
Thanks, i'll double check that. The last oil change i did, I gave everything a once over and didnt get any movement on anything, which leads me to believe I have the Clunk. errr.
Old Nov 24, 2007 | 07:00 PM
jimmyloose's Avatar
jimmyloose
Any regular wrench should fit in there... A socket, not so much.
Old Nov 24, 2007 | 07:05 PM
grudum's Avatar
grudum
ayite.. i'll pop the wheel off and give her hell. the night i did the oil change i tried to loosen the lugs and ended up tearing the lug key because the tire jockeys torqued em too much. I just went back to get em to loosen and re-torque to spec, so i'll have to get in there and give it a shot this week.
Old Nov 24, 2007 | 07:11 PM
Zridder19's Avatar
Zridder19
Could be broken sway bar, steering rack, or where the lower control arm goes into the spindle.
Old Feb 22, 2008 | 04:10 PM
Rappo25's Avatar
Rappo25
I just got my car back from Nissan. I have the same problem and sent it in to have the endlinks replaced... but it still makes that noise. I should probably try and diagnose this issue before it gets worse. I should keep the .9G turns to a minimum
issyz
Jul 2, 2017 03:04 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
Beater350z
Sep 9, 2015 03:36 PM
