GT Spec front lower tie brace install
Old Jul 26, 2009 | 07:38 AM
misterniceguy's Avatar
misterniceguy
Some of the bolts are for adjusting the alignment. Just mark those with a marker and return it to the original position if you twist them.
Old Nov 20, 2009 | 11:39 PM
silverbullet_Z's Avatar
silverbullet_Z
Originally Posted by SpoilsofWar
^It will work with a GReddy oil pan. That is the only aftermarket pan or spacer that it will clear. And JUST BARELY.
I have had all the GT Spec bars at one time or another, minus the ladder bar because I have the Tanabe brace anyway, and I would say that the front tie brace is probably the least useful. I couldn't tell any difference with it on or off, and when you look at where it is installed, it just doesnt seem to be an area that would benefit much from bracing. But, I am not an automotive engineer and that is just my $.02.
And oil changes are not affected at all by having the brace, beside that some oil will get on it when you pull the drain plug.
does GReddy still sell that oil pan i cant find it anywhere other than it comes with greddys TT kit, Can someone else varify that that is the only pan that will fit under the GT Spec Brace?? how about APS??
James1990
Dec 16, 2015 08:57 PM
Mikey3288
Mid-Atlantic Marketplace
Oct 23, 2015 07:41 AM
CJs_Z33
Sep 18, 2015 12:06 PM
Mw870
Sep 10, 2015 07:50 PM
