alignment specs is whack! help?
Old Dec 4, 2007 | 05:49 PM
MyLilBlkG's Avatar
MyLilBlkG
Default alignment specs is whack! help?
well just got my alignment done and here's the spec.
FRONT
Left .................. :Right
-1.0 ... camber ... -3.1
7.5 ... caster ........ 8.7
.04 ... toe .......... .05
6.1 ... SAI .......... 5.8
5.1 ... Included angle ... 2.7
turning Angle diff.
REAR
Left ........... Left
-2.6 camber -2.3
.027 toe .12
what is up with the front right? the right-side drop (on tein basic) is the same as the left, same wheel gap and everything, but why the big difference?
can someone tell me if the rest is decent? anything i need to do?
i did this at firestone in garden grove and they did SH*T and charged me full price. I initially wanted to do an alighment check (which is $20) but the effort they took to get my car on the lift and what not (i had to take off my own bumper), but when i look at the sheet, the only thing they touch is the front toes. Not coming back there for sure.
has anyone heard of Vodies aligntment?
thanks in advance
Old Dec 4, 2007 | 05:52 PM
ricepeck's Avatar
ricepeck
too much math, sorry. j/p Maybe some of the experts on the forum can help?
Old Dec 4, 2007 | 09:29 PM
toples z's Avatar
toples z
your caster and angles can be adjusted if you take it to a shop that knows what they are doing. You will deffinatly need some camber kit for front and back, ASAP if you dong get one your tires are going to get raped, wich will coast you much more money then the camber.
Old Dec 5, 2007 | 05:27 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
did you buy the car new? Was it ever hit? What offset on your wheels/tires?
Rear camber is way too high also, and toe is totally off
Old Dec 5, 2007 | 07:36 AM
WTX350Z's Avatar
WTX350Z
Included angles should be that much different...good that SAI is almost same bilaterally. Prolly due to camber spread....
Camber is trashed...I'm hoping you have aftermarket camber adjustment I'm not familiar with them, but I am familiar with suspensions, and alignments.
DO the aftermarket front camber adjustments allow for caster adjustment? If so, it should be fixable.
If Car is lowered, this will cause the excessive camber, and thus alter toe settings. If you lowered it you need all the extra adjustable camber/toe parts that can be bought...to correct what you just ruined....
Old Dec 5, 2007 | 12:05 PM
MyLilBlkG's Avatar
MyLilBlkG
yes car was purchase new, was hit once on the left front (would that mess up the right though?). tires are rear: 275/35/19 and fronts: 245/35/19...don't remember the offset for the RH R5.
don't have any aftermarket camber adjustment, but i will now.
does anyone know if camber adjustment kits allow caster adjustment?
has anyone had their alignment done at West End? Vodies? or any other 714 recomendation?
thanks
Old Dec 6, 2007 | 03:19 AM
Nukiz0r's Avatar
Nukiz0r
Subscribing.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
