brakes still squeaking after replacing pads
Old Dec 5, 2007 | 11:28 AM
rfdgn1228's Avatar
rfdgn1228
Default brakes still squeaking after replacing pads
my rear brakes are still squeaking after replacing the brake pads. i was told i didn't need new rotors so i just had them re-surfaced. could this be why they are still squeaking?
i'm thinking it could either be the pads themselves or the rotors.
any ideas on what the problem is? thanks guys. its just really annoying because i replaced my pads to stop the squeaking in the first place.
Old Dec 5, 2007 | 11:35 AM
ANXIOUZ's Avatar
ANXIOUZ
Looking at your sig...do you have OEM regualar rotors/pads in the rear?
Old Dec 5, 2007 | 11:45 AM
rfdgn1228's Avatar
rfdgn1228
i replaced the oem pads in the rear with prostop ceramic brakepads and resurfaced the oem rotors.
Old Dec 5, 2007 | 11:47 AM
VO...'s Avatar
VO...
Administrator
I did an entire write up on this about a week or two ago...
Old Dec 5, 2007 | 12:35 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
did you get backing plates? Did you use anti squeal compound?
Old Dec 5, 2007 | 07:10 PM
rfdgn1228's Avatar
rfdgn1228
i'm not sure. is there a way i can find out or should i just bring it back to the shop where i got them replaced?
rfdgn1228's Avatar
rfdgn1228
i can't find it. are you referring to your rear BBK install?
Old Dec 6, 2007 | 04:50 AM
Z1 Performance
Former Sponsor
yes
Old Dec 6, 2007 | 06:19 AM
VO...'s Avatar
VO...
Administrator
This thread, start @ post #4:
https://my350z.com/forum/showthread....akes+squealing
Old Dec 6, 2007 | 09:35 AM
rfdgn1228's Avatar
rfdgn1228
thanks. i've only had the brake pads in for about 2 months (is that long enough for break-in). i'll give it sometime and see what happens.
Old Dec 6, 2007 | 09:53 AM
VO...'s Avatar
VO...
Administrator
I'm really not sure. I can tell you the anti-squeel compound didn't work in my case. I took the Z out Tuesday night and it squealed like a pig at every stop. I'm ordering new pads after Christmas...
350z82
Oct 1, 2015 06:25 PM
