Are you replacing yours? It would be better to get some stronger and adjustable ones from SPC or Z1 Performance. They do cost more, but well worth it.
I was looking at those but figured they were more then I need. I am still on OEM suspension except for the sway bars (stillen). Unless the OEM are super expensive I cant justify the cost.
However the Z1 performance links look like an amazing piece.
It would be better to replace the stock endlinks with a aftermarket upgrade, like powergrid. You'll probably just keep wearing out your stocks with the sways.
well, to answer your question, it's 54618 for the front and 56261 for the rear. keep in mind that they are different for left and right. you could see on that website that the "H" denotes which side they go on.
i have the same setup as you. (oem suspension and stillen sway bars). I assume you also have noise coming from the rear OEM endlinks?
