Suspension work for my Z
Originally Posted by kihun
I'm not trying to go race at track or anything. I'm trying to lower my car a little from stock height. What's popular cheap set up? Could you also provide pictures too? Thanks =)
A little drop to me would be Tein 350Z H-techs, S-techs, Hotchkis, RSR or Swift (not the spec-R)
Define the drop amount in numbers that your after as in a min and max.
In case this helps here's a master list of springs and specs.
Oem spring rates
350Z 2003/2004
Front:314 Rear:342
350Z 2004.5 to 2008
Front:314 Rear:427
Eibach 350Z progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach 350Z sportline progressive springs 1.2"/1.2"
F: 239/400 R: 257/435
Very wide spreads between the softer initial rates and firmer peak rates.
RSR 350Z linear springs .6”/.6”
Spring rates in LBS 345/417
Hotchkis 350Z Linear springs .6”/.8”
Spring rates in lbs 340/330
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2”
Spring rates in LBS 358/375
Progress Technology progressive springs 1.0”/1.0”
Spring rates in LBS 425/385 (final rates only, softer intial front progressive rate unknown)
Tokico D-spec shock & spring package
350Z - DSK512 - 375f/375r - Linear Springs 1"/1.5"
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown) Not much stiffer vs oem, IMO Eibach prokit is a better choice because of that springs higher spring rates which should help keep you off the bumpstops more often.
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” higher
Spring rates in LBS 314/353
Little to no increase in spring rate over oem, little to nothing added to keep you off the bumpstops
Swift 350Z linear springs .8”/.6”
Spring rates in LBS 336/364
Swift 350Z Spec-R progressive springs 1.2”/1”
Spring rates in LBS intial/final Front: 291/392 Rear: 280/448
Nismo T2 350Z Linear springs 1”/1”
Spring rates in LBS 625/700
Way too much spring for oem shocks or Tokico D-specs, HP, GR2 or Bilstein Sport(unless revalved). Koni sports are debateable.
Vogtland 350z progressive springs 1”/1”
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Kg/mm DRacing progressive springs 1.2”/1.2”
Spring rates in LBS initial/final front 252/454 initial/final rear 252/482 rear
Whiteline 350Z linear springs (control)
Front: Part # 73219,
Spring rate 365 LBS Drop: .8"-1" (will be higher on a G35)
Rear: Part # 73220
Spring rate 445LBS Drop: 1"-1.2" (will be higher on a G35)
(sold as 2 front springs and 2 rear springs)
www.whiteline.com.au/store/
Espelir 350Z progressive springs 10mm drop F&R
386/515 (softer initial progressive rates are unknown)
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
I had eibach prokit springs and i hated the performance so i got Kbee coilover and am now happy with the looks and added performance. Coilovers are a bit pricey but I'm of the opinion that modifying a car should not only be for looks but also involve improved functionality
Originally Posted by Escobar
I forgot about the alignment as well. How much did they charge you for installation, or did you do it yourself? Just for the springs.
if i had garage and tools, i probably try to do myself.
since i got nothing so i took it to shop.
they charged me 200 ~ 300 between there i forgot.
but it's better u study before you go. and watch them if they do right.
this guy forgot to install my camber TOE BOLT.
thanks to one of 350z member's tread!
- alignment took it to firestone, other alignment shop couldn't do it, ( they said my car was too low.
https://my350z.com/forum/showthread....ight=tanabe+GF
350Z_Al
Oct 29, 2020 07:44 PM
