stock suspension adjustability
Old Dec 26, 2007 | 10:01 PM
Equinox's Avatar
Equinox
Default stock suspension adjustability
Does the OEM suspension allow for any adjustment of camber, caster, and toe? I see lots of people running aftermarket camber arms and such but do the stock components allow for any adjustment?
Old Dec 27, 2007 | 12:03 AM
mthreat's Avatar
mthreat
For the front, the OEM suspension allows toe adjustment only. If you lower your car (with aftermarket springs), as a side effect, you often get more negative camber. I use SPL's front camber arms, which add camber and caster adjustment:
For the rear, it allows toe adjustment, but I'm pretty sure it doesn't allow camber (I could be wrong). SPL also makes some rear suspension parts to allow camber.
Old Dec 31, 2007 | 09:47 AM
Gsedan35's Avatar
Gsedan35
Front: Toe
Rear: Camber and Toe
Keep in mind that in the rear, when you remove negitive camber you also effect toe. When you correct with aftermarket parts get parts to correct both camber and toe.
